Compressive strength of aluminum
The discussion revolves around the compressive strength of aluminum, specifically addressing whether aluminum bars or load cells made from the same type of aluminum (such as high purity aluminum or various aluminum alloys) exhibit identical compressive strength or if variations exist. The scope includes theoretical considerations, material properties, and practical implications in manufacturing and calibration.
  • Experimental/applied
  • Some participants propose that variations in compressive strength can occur even among aluminum bars made from the same alloy due to factors like density and imperfections.
  • Others argue that experimental variability exists, influenced by standards that may include performance, compositional, and processing criteria.
  • A participant notes that porosity can also affect compressive strength, regardless of the material being the same.
  • It is suggested that achieving identical compressive strength between two load cells may require fine-tuning during manufacturing and calibration processes.
  • Concerns are raised about the inherent tolerances in load cell sensitivity, modulus of elasticity, and strain gauge measurements, which can lead to discrepancies in performance.
  • Some participants discuss the impact of the manufacturing process (e.g., extrusion, rolling) and heat treatment on the characteristics of aluminum alloys.
Participants generally agree that variations in compressive strength can arise from multiple factors, including manufacturing processes and material imperfections. However, there is no consensus on whether two bars made from the same aluminum alloy can be expected to have identical compressive strength, as opinions vary on the extent of variability.
Limitations include the dependence on specific definitions of "exactly similar" and the variability introduced by manufacturing tolerances and standards. The discussion does not resolve how to achieve identical compressive strength or the implications of accuracy specifications.
This discussion may be of interest to materials scientists, engineers involved in load cell design, and professionals concerned with precision measurements in mechanical applications.
  • #31
Rev. Cheeseman (private message) said:
jack action said:
Two samples will never be alike mainly because of the randomness of the crystal structure defects where impurities, dislocations, and grain boundaries will be slightly different.
So in other words, the inner structure is not consistent inside an aluminum bar therefore the compressive strength will be inconsistent along the length of an aluminum bar?
Metal products have defects just like wood does. The fabrication process is more controlled, so the defects are smaller and more uniform, but they are still there.
(source)
Metals at the microscopic level:
(source)
(source)
Introduction to the wonderful world of metallurgy:
  • #32
Rev. Cheeseman said:
Is calibration the same as when we try to drop things on load cell?
Does one mean dropping a mass or load onto the specimen? A drop test is a dynamic test, i.e., relative high load/strain rate, which will affects test results. Strain rate is a factor in both tensile, compressive and shear testing; some alloys are more sensitive than others.
Re: https://www.physicsforums.com/threads/compressive-strength-of-aluminum.1063600/post-7096651
As jack action mentioned, no two specimens will necessarily test identically for the reasons described. There can be small differences in composition (local inhomogeneity compared to bulk/nominal), which can be minimized for products from the same lot. However, one will find some process (thermomechanical processing history) variability, leading to slight variations in microstructure (grain size, grain orientations, dispersed second phase particles, . . . . ), which will contribute to the variability in testing results. In the case of aluminum, storage temperature and time (ageing) of the finished product is also important.
Factors affecting testing variability include differences in load/strain rate, alignment or misalighnment of grips or loading system, variability in specimen and testing temperature, just to name a few.
  • #33
It might be useful to make both aluminium pieces from the same bar stock. If you want the properties to be nearly the same. If made from the same bar stock then the same heat number will apply to both pieces so the material properties of both pieces will be as close to identical as you could possibly make it. Then it's down to machining tolerances on the indicidual parts.
  • #34
Baluncore said:
Buy one bar, then cut two from it.
Notice that the -T6 tells you that it has been treated to make it hard and dimensionally stable. Avoid overheating it during cutting or machining.
"T6 temper 6061 has been treated to provide the maximum precipitation hardening (and therefore maximum yield strength) for a 6061 aluminium alloy."
https://en.wikipedia.org/wiki/6061_aluminium_alloy#6061-T6
If you want them to be very similar I agree with @Baluncore. That should be the easiest way to achieve it. There will still be some variation as others have mentioned but that's always the case.
Also, as others have mentioned as well, without knowing the application for these components it's harder to assess the best approach. Typically, the small variability is not an issue since the strain limit is often far away from the working conditions. If a 1% variability breaks your system then you probably need to change your design in the first place.
Lastly, as a side note, you've talked about compression and taking it at very high values. Again, I don't know the application but, just in case, I advise you to check for buckling.
  • #35
TL;DR: Do aluminum bars or anything made from the same type of aluminum have the same exact compressive strength for each of them?
Hello,
Do all of aluminum bars (or load cells) made from the same type of aluminum (i.e high purity aluminum or different types of aluminum alloys) share the same exact compressive strength or are there variations in compressive strength even among the same type of aluminum like high purity aluminum or same type of aluminum alloy?
Short answer: no.
Even if two aluminum bars are nominally the same alloy, their compressive strength won’t be exactly identical in practice. The alloy designation only defines a typical range.
Things like temper (annealed vs. T6), extrusion vs. forging, grain size, and residual stress all matter. High-purity aluminum is generally weaker than most alloys, but even within high-purity material you’ll still see some spread due to processing history.
This is why for load cells and other precision components, engineers don’t rely on “aluminum type” alone — the full material specification and calibration matter much more.
  • · Replies 37 ·
14K
  • · Replies 19 ·
