Compute the charge on the capacitor
  • Thread starter Thread starter fubag
    Capacitor Charge
The discussion focuses on calculating the charge on a capacitor 10.0 ms after a switch is toggled from position 2 back to position 1. The voltage across the resistor before the switch is thrown is 8.28 V, and after it is 9.72 V. The capacitor has a capacitance of 1.30×10-5 F, a resistor of 990 Ω, and an emf source of 18.0 V. The relevant equations for charging and discharging capacitors, including V = E(1-e-t/RC) and I = (E/R)e-t/RC, are essential for solving the problem.
  • Understanding of capacitor charging and discharging equations
  • Familiarity with the concepts of resistance (R) and capacitance (C)
  • Knowledge of exponential decay in electrical circuits
  • Ability to manipulate equations involving voltage (V), charge (Q), and time (t)
  • Learn how to derive the time constant for RC circuits
  • Study the impact of varying resistance and capacitance on charge time
  • Explore practical applications of capacitors in timing circuits
  • Investigate the effects of internal resistance in real-world capacitor circuits
Students studying electrical engineering, physics enthusiasts, and anyone involved in circuit design or analysis will benefit from this discussion.
fubag
http://img259.imageshack.us/img259/1535/question2az5.th.jpg
Compute the charge on the capacitor 10.0 ms after the switch is thrown from position 2 back to position 1.I know from previous parts of this problem that the Voltage across the resistor before the switch is thrown is 8.28 V. Afterwards it is 9.72V.
I figured that the charge q before switch is thrown is 133 micro coulombs.
I tried using the new voltage after the switch is thrown to find q but it didn't work. Can someone please help me out?
C = Q/V;
and I found the voltages using the equations relating to RC charging and discharging.
but I am still not getting the right answer.
I can't tell you what you did wrong, because you didn't show your work. Didn't the problem
give R, C and E?
What kind of equation governs a capacitor?
You're looking for an equation with time t in it. You're going to need that to use your given value of 10.0 ms.
A capacitor with C = 1.30×10−5 F is connected as shown in the figure View Figure with a resistor with R = 990 Omega and an emf source with E = 18.0 V and negligible internal resistance. Initially the capacitor is uncharged and the switch S is in position 1. The switch is then moved to position 2, so that the capacitor begins to charge. After the switch has been in position 2 for 10.0 ms, the switch is moved back to position 1 so that the capacitor begins to discharge.I used the equations for V and I for discharging and charging capacitors.
V = E(1-e^(-t/RC)) charging
V = V_oe^(-t/RC) discharging
I = (E/R)e^(-t/RC) charging
I = (V_o/R)e^(-t/RC) dischargingI then used C = Q/V to find Q for the first part where before switch is thrown...hope this helped clarify some things, sorry for the lack of info
  • · Replies 62 ·
