Computing Curvature of Space at Point from Mass - Help Needed
xortdsc
Hello,
given a stationary pointlike particle with mass m at some position, I'm trying to compute just how much space is curved/deformed at a distance r from that particle due to its gravitational field.
I'm not really into all that tensor calculus, so I really struggle with the equations given in literature. I hope someone here can clear things up a little.
If I understood that whole SR/GR good enough I'd think it should be possible to compute a (3d vector) field, which in my particular case is still only dependent on the particles mass and the distance from it, which holds the "ratio" of spatial deformation compared to uncurved space (absence of any energy/mass which therefore would yield 1 everywhere).
I'm particularly interested in this ratio, which basically tells me how much space "scales" for each axis for an outside observer.
Thanks and cheers !
Sounds like you are asking about the spatial part of the Schwarzschild metric.
http://en.wikipedia.org/wiki/Schwarzschild_metric#The_Schwarzschild_metric
The ratio of proper radial distance to difference of circumferences divided by 2pi is (1 - rs/r)-1/2
Ah, so "sqrt(1-rs/r)" is simultaneously the time dilation ratio and space curvature ratio at distance r. Do I interpret this correctly ?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
