Computing the homology of R^3 - S^1
  • Thread starter Thread starter bham10246
    Computing
The discussion focuses on computing the homology of R^3 - S^1, with initial claims that H_0 is Z due to path connectivity, and uncertainty about H_1, which is suggested to be Z. The analysis explores the relationship between R^3 - S^1 and other topological spaces, concluding that H_1 is Z and H_2 is 0 under standard embeddings. It is noted that the homotopy type of R^3 - S^1 depends on the embedding of S^1, and the fundamental group contributes to the homology calculations. The conversation also touches on the nature of maps between homology groups, particularly questioning why a certain map must be constant, leading to further algebraic conclusions about H_1.
bham10246
Compute the homology of R^3 - S^1.
Actually a friend of mine asked me this question and I came up with the following way to solve this but I'm not sure if it's correct.
My analysis:
H_0 = Z (the integers) because it's path connected.
H_1 = Z (the friend said so but I don't believe him)
H_2 = ??
R^3 - {point} = S^2 (= means homeomorphic to or homotopic to)
R^3 - {line} = S^2 - {2 points} = R^2 - {1 point}
So R^3 - S^1 = R^3 - {a line together with a point at infinity} = R^2 - {2 points} = figure eight
Is this a valid reasoning? If so, then H_0 = Z, H_1 = Z direct sum Z, H_2 = 0.
Thanks.
Mathematics news on Phys.org
I don't know much about this stuff, but I know that the homotopy type of R^3-S^1 actually depends on the choice of embedding of S^1. I remember my professor said they can use the homotopy of R^3-S^1 to study knots.
So it depends which S^1. But I think it's clear that under the standard embedding of S^1 H_n=0 for n>0. I could be wrong about this though.
There are such things as excision formulae, you know. I think we can assume that S^1 means the natural copy of S^1 sitting in the x-y plane.
It seems reasonably clear to me that H_1 is Z, since the fundamental group is Z (you just count the number of times you loop around the copy of S^1), and H_1 is the abelianization of the fundamental group. This just leaves H_2 to work out.
But wouldn't looping around the copy of S^1 be trivial (since we can just pull the loop into the z-plane a little and then deform it to a point).
EDIT - never mind, I'm an idiot.
Thanks. You guys are fantastic! Yes, so if we take A = S^1 and X = R^3, then I got
H_3 (X,A)=0,
H_2 (X,A)= Z,
H_1 (X,A)= Z,
H_0 (X,A)= Z.
Can someone explain to me why the map f: H_0(A) --> H_0(Z) must be a constant (the zero) map? If this is a constant map, then I was able to conclude (algebraically that) H_1 (X,A)= Z.
H_1(X)=0 --> H_1(X,A) --> H_0(A) =Z --> H_0(X)=Z --> H_0(X,A) --> 0
It suffices to show that the map H_0(X)-->H_0(X,A) is the identity map (or an isomorphism, at any rate), to demonstrate that the map H_0(A)-->H_0(X) is the zero map. Can you do this (I've not thought about it, to be honest).
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
