What is the Practical Application of ZSR and Delta Function in Circuit Theory?
  • Thread starter Thread starter electron2
    Diagram
The discussion focuses on understanding the practical application of Zero State Response (ZSR) and the Delta function in circuit theory. Participants express confusion about transitioning from the step function to the Delta function and seek practical examples and reading materials. One contributor mentions that using ZSR responses to both the Delta function and the "duplete" function can yield the same results without complex derivatives. Suggestions for further reading include links to Wikipedia and Wolfram articles, as well as a recommendation for the book "Basic Circuit Theory." The conversation highlights the need for clearer explanations and resources in electrical engineering forums.
electron2
i can't understand translate these words :
"instead of going from u(t) (step function) to delta function (shock function)
via derivative,
we go from u(t) to reaction of zsr to u(t)
and the we go to the reaction of zsr to shock function (delta function)
i am looking for
practical example ,or some more reading material to this.
i know what a step function.
my lecturer said that "there are circuits which asks us to calculate
the response on duplete function.
for that we need to do a derivative from delta function to duplete
which is very complicated.
instead we do zsr response to delta and zsr response to duplete and we get the same result"
does that ring a bell
i want an example on this stuf
i can't understand teh process
example example example
I'm not an expert in controls or communications (where you're most likely to encounter this sort of thing from an EE standpoint), however, I can't recall having had to use the derivative of the delta-dirac function for anything, and a search for the 'duplete' function brings up your post, and misspellings of 'deplete'.
You're probably better off asking your lecturer (or waiting for a response from someone who may better understand your question), as it's been a number of years since I've had to do anything like that. When we did use it, it was convolving the impulse response of a system with an arbitrary input in order to find the system response to that arbitrary input.
In the meantime, perhaps equations 14 through 17 of the Wolfram article on the Delta Dirac function are applicable?
http://mathworld.wolfram.com/DeltaFunction.html
Sorry I can't be of any more help, in this case.
have you heard of
desour " basic circuit theory"
this is a book about such stuff.
can you suggest to me some hardcore electrical engeneering forums.
i visited several already
and in all of them i was given responses like "what is ZSR i haven't heard of it"
"whats delta function" etc..
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
