Concentrations of electrons in intrinsic semi-conductor
  • Thread starter Thread starter jendrix
    Electrons
The formula for electron concentration in intrinsic semiconductors is expressed as n ∝ T^(3/2) exp(Eg/(2kBT)), indicating that n is proportional to the temperature and the exponential term. The discussion clarifies that "n" represents a density, which has units of m^-3, while the right-hand side of the equation has a different unit structure. The temperature dependence is highlighted as the effective density of states related to the conduction band edge. Understanding the proportional relationship is essential for accurate calculations in semiconductor physics. This clarification aids in applying the formula correctly in practical scenarios.
jendrix
Hi, I've just started using the formula for the abovie which is given as:
n t^3/2 exp(Eg/2kBT)
however instead of n= I think the sign is n is proportional, like this ∞
I was wondering which would be correct?
Thanks
Thanks
Yes it's definitely proportional to, not equals. That is, n \propto T^{3/2} \exp(Eg/(2k_BT)).
You can "see" this easily enough by looking at the dimensions (units) of each side of the equation. The term "n" is a density, and therefore m^{-3} (or cm^{-3} etc), whereas the unit on the RHS is T^1.5.
The "T^(3/2)" factor is merely the temperature dependent part of the equation for the "effective density of states referred to the conduction band edge", if you want to google that.
I see now, thanks :)
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
