What is the Purpose and Significance of Complex Numbers in Engineering?
In summary, complex numbers are convenient for doing ordinary algebra to solve two-component problems. They also allow us to describe the force exerted on a physical object, like a person in free-fall, in terms of a magnitude and a direction.
afarzana1
Hellow
My question is about Complex number.
I can solve and calculate complex numbers. But i m still Unsure about the Concept of Complex number.
I have read many articles and they say that a symbol i is added to make the solutions possible.\
In communication engineering, as well as Electrical engineering, this number plays an important role.
Keeping this in mind, Tell me what does the real part and imaginary part of a Complex number shows with an example..Take capacitor or Inductor.
We have learned in primary classes about the Numbers with Fundamental Concepts.
Tell me the Fundamental Idea and Concept of Complex number in context to any application or Example so that the idea behind the number can be visualized properly.
We talk a lot about impedance in transmission lines and they all are in complex number,even in Electrical Machines, Transformer or Motors, I don't understand where actually the real and imaginary part lie? What does the Real part in practical as well as the imaginary part shows??
Can you Evaluate or Mark and show me from some observation ( or from graph ,a point ) practically and name it complex number with real and imaginory?
Saying so , Please share links,Flash Demonstration, so that i can easily understand this number fundamentally!
And why the real part and imaginoary part are added?? to combine a new number,? and how?
Justify with REASONS AND EXPLANATION
And since symbol "i" is imaginary , how one can translate the word imaginary?Even knowing the complex number hold a significant value in engineering?Does "i" have some transformation?
Thanks
Regards
In EE complex numbers are convenient for doing ordinary algebra to solve two-component problems.
Analyzing circuits at a frequency S turns the differential equations of a circuit into algebraic ones. Laplace transform for example.
A complex number has a magnitude and a phase. A real number only has a magnitude so it's not easy to solve frequency-domain problems (where every system changes the amplitude and phase of the input but is still sinusoudal.)
Think of a number. Say, 150. What can you do with it? Not much! It's bigger than 149. Yawn.
Now if you wanted to convey information about the weight of your mother, simply saying "150" would be meaningless. 150 what? Tonnes? LOL, of course not -- you meant 150 kg, and that calls for a scalar quantity, which is simply the product of a numerical value and a physical unit.
But what about the situation where your mother is in free-fall after a parachute jump from a high-altitude balloon? How can we talk about the force that is acting on her body? Well, from the sound of her screaming, we know she's accelerating, and Newton's Second Law or whatever tells us Force = (mass * acceleration). But in what direction is she accelerating? Is she going up? Hell, no. She's going down. So the Force has a magnitude of m*a (measured in kg*m/s^2) and a downward direction. The Force is a vector!
Notice how we went from a simple number to a scalar, and finally to a vector, and how we were able to increase the amount of information along the way. A complex number is also a vector with a magnitude and a direction (or "phase angle") as any other vector. In the same way that the force vector allowed you to describe your mom in free-fall, complex numbers makes your life easier by, e.g., giving you a way to describe the how the phase of a electrical signal varies with time, etc.
Related to What is the Purpose and Significance of Complex Numbers in Engineering?
What is a complex number?
A complex number is a number that contains both a real part and an imaginary part. It is written in the form a + bi, where a and b are real numbers and i is the imaginary unit, equal to the square root of -1.
What is the purpose of using complex numbers?
Complex numbers are used to represent quantities that cannot be expressed using only real numbers, such as solutions to certain equations and quantities with both magnitude and direction. They are also used in various fields of mathematics, science, and engineering.
How are complex numbers represented on a graph?
Complex numbers are represented on a graph called the complex plane, where the real part is plotted on the horizontal axis and the imaginary part is plotted on the vertical axis. The point where the two axes intersect represents the complex number 0 + 0i, known as the origin.
What is the conjugate of a complex number?
The conjugate of a complex number a + bi is the complex number a - bi. It is obtained by changing the sign of the imaginary part. The conjugate of a complex number has the same real part but an opposite imaginary part.
What is the modulus of a complex number?
The modulus, also known as the absolute value or magnitude, of a complex number a + bi is the distance from the origin to the point representing the complex number on the complex plane. It is calculated using the formula √(a² + b²). The modulus of a complex number is always a positive real number.
  • Electrical Engineering
  • Classical Physics
