Conceptual question about torque
  • Context: Undergrad
  • Thread starter Thread starter stingray191
    Conceptual Torque
The discussion centers around the concept of torque and its relationship to the rotation of an object in space, particularly why an object "chooses" to rotate around its center of mass when torque is applied. Participants explore theoretical implications, conservation laws, and practical examples related to this phenomenon.
  • Some participants suggest that the minimal moment of inertia occurs about an axis through the center of mass, which allows for the most effective rotation.
  • One participant proposes that conservation of linear momentum plays a role in why rotation occurs around the center of mass, although they express uncertainty about the fundamental reasons for momentum conservation.
  • Another participant discusses the decomposition of motion into linear motion of the center of mass and rotational motion, questioning the definition of the lever arm without assuming the center of mass as the center of rotation.
  • Some participants challenge the initial premise by providing examples where torque does not lead to rotation about the center of mass, particularly in practical scenarios involving force application at varying distances from the axis of rotation.
  • There is a mention of quasi-particles and the practical implications of using the center of inertia in calculations, although the nature of these concepts remains debated.
  • A later reply emphasizes that conservation laws, such as linear and angular momentum, are fundamental but do not provide a complete answer to the original question posed.
Participants express a range of views, with some agreeing on the role of moment of inertia and conservation laws, while others contest the applicability of these concepts to the original question. The discussion remains unresolved with multiple competing perspectives on the nature of rotation and torque.
Some limitations include the dependence on definitions of torque and lever arm, as well as the assumptions made about the conditions under which the discussion is framed. The relationship between linear and angular momentum is also not fully resolved.
stingray191
Imagine an object in space with no other forces acting on it. Why is it that if you apply a torque on the object, it will rotate around its center of mass? That is, why does it "choose" to rotate around the center of mass? I can't come up with an answer and this question has been bugging me for a long time. Any sort of insight would be greatly appreciated.
The minimal moment of inertia is about an axis that passes trough the center of mass.
In addition to what bp_psy said - the minimal moment of inertia allows for the most effective rotation (an object would most likely rotate around an axis that is the easiest to rotate around).
It is conservation of the linear momentum. Imagine the object as a bunch of point masses, let's say just two identical ones. Rotation around any other point than their midpoint would mean that the sum of their linear momentums varies over time.
Why linear momentum is conserved, we don't know.
Since a torque is defined as a force applied via a lever arm, there is a change to the *angular* momentum. Although the general motion of the (rigid) object will allow for movement of the center of mass, the total motion can be decomposed into linear motion of the center of mass (given by the component of the impressed force parallel to the lever arm) and a rotation given by the component perpendicular to the lever arm.
1) I don't understand you decomposition. The force component perpendicular to the lever arm, doesn't only cause rotation it also causes linear motion.
2) How do you define the lever arm anyway without already assuming the center of mass as the center of rotation?
3) All that doesn't answer the OP question, why for a freely rotating object in space it is the center of mass that moves inertially (or is at rest). The answer to that in terms of a more fundamental law is given in post #4.
Such a decomposition follows form the Newton equations. As soon as you have at least two particles, one can introduce the notion of the center of inertia R. Its equations are free ones in absence of an external force. The relative coordinate motion is determined with inter-particle forces; normally it is oscillations and rotations. But the notion of CI is valid even for non interacting particles. It is just such a variable that depends on external force solely.
Although looks trivial, I would like to let you know that equations for CI coordiante R contain the total mass M. There is no such a particular particle with such a mass actually, that is why the CI is called a quasi-particle. Its equations are particle-like (Newton ones) but for non existing particle. Still, it is very practical: we often assocoate R with the body coordinates if we look from far away.
Similarly, the relative distances like r = r1 - r2 are determined with reduced masses so they also correspond to quasi-particles. It is important to understant that often (if not always) we observe quasi-particle properties - proper oscillation frequencies, average motion, etc., not particle ones.
A.T. said:
<snip>
We may not 'know' in a philosophical sense, but we do know that linear momentum is conserved because the result of an experiment does depend on *where* in the universe it was perfomed, and angular momentum is conserved becasue the results of an experiment do not depend on the direction we are looking when we perform the experiment.
Conservation of energy occurs becasue the results of an experiment do not depend on *when* we perform the experiment.
(Noether's theroem).
In replacing a flat tire, I tighten the lug nuts (on an 8-cm radius) by positioning the lug wrench handle directly over the wheel's axis of rotation. If my hand is closer than 8-cm from the lug, the wheel rotates one way when I apply force. If my hand is further than 8 cm, the wheel rotates the other way when I apply force. There is a point at 8 cm (when my hand is directly at the axis of rotation) where there is no rotation about the wheel's center of mass at all, even if the wheel is floating in free space. So your statement "Imagine an object in space with no other forces acting on it. Why is it that if you apply a torque on the object, it will rotate around its center of mass" is not always true.
Right. In this special case, the force is applied in a line that passes through the centre of mass, thus zero torque.
However, correct me if I'm wrong, this state can only exist instantaneously. As soon as the wrench tightens the nut through any angle, the distance changes, causing torque to rise from zero. It works OK when there's friction on the wheel, but would not work in free-floating space.
In this case, I would use a ratchet torque wrench.
[Edit] In every case, there will be a linear momentum transfer to the object. When I tighten the wheel lugs, the axle is on a jack, and the wheel is free to rotate, so my hand position has to be in line with the axle.
Bob S said:
...my hand position has to be in line with the axle.
Yes. My point was merely that it only starts off in line with the axle. The geometry changes as soon as the nut turns (which is relevant to the OP).
It won't, the center of rotation will depend on where the torque is applied. Imagine a rocket with a side nozzle at one end and an opposing side nozzle in the middle, as opposed to the other end. If the opposing nozzle is at the other end (and the thrust is the same), the rocket's center of mass doesn't move. If the opposing nozzle is not at the other end, then the rocket's center of mass moves in a circle.
Even when the opposing nozzle is not placed at the other end and as long as the net force(due to the releasing gases from the nozzle) on the rocket is zero, COM wouldn't accelerate.
So i think we can sum it up as,
Non-zero force;non-zero torque *may* have a different center of rotation.
Zero force; non-zero torque *should* have the COR at the COM.
  • · Replies 19 ·
  • · Replies 67 ·
