Condensation of gas using bernoulli's principle
The discussion centers on the theoretical application of Bernoulli's principle to the condensation of butane gas in a pipe. When a constriction in the pipe accelerates the gas, the resulting drop in pressure can indeed lead to condensation under the right conditions. The total enthalpy is conserved, meaning that an increase in kinetic energy results in a decrease in sensible enthalpy, facilitating the condensation process. This principle is also relevant in aviation, where carburettor icing can occur due to similar pressure drops in the venturi effect.
  • Understanding of Bernoulli's principle
  • Knowledge of gas dynamics and enthalpy
  • Familiarity with the properties of butane and its phase changes
  • Awareness of carburettor systems in aviation
  • Research the application of Bernoulli's principle in fluid mechanics
  • Study the phase behavior of butane and other hydrocarbons
  • Learn about carburettor icing and its prevention methods
  • Explore the design and function of venturi systems in various applications
Engineers, physicists, aviation professionals, and anyone interested in fluid dynamics and gas condensation processes.
bitman
hi experts
This ought to be obvious but it sounds wrong.
If I have a pipe carrying butane at a constant flow rate at room temperature fed from a liquid gas bottle without a restrictor so that the gas is almost condensing, then have a constriction in the pipe to accelerate the gas, will the drop in pressure caused by acceleration cause the gas to condense ?
This is a purely theoretical question so no actual gases will be used. Just interested to see if gases can be condensed this way.
Many Thanks
bitman
Read an earlier thread on this forum re carburettor icing but it wasn't clear if this was the reason.
Yes. The constriction conserves total enthalpy. If the kinetic energy of the fluid goes up, its sensible enthalpy goes down. Condensation is certainly possible under appropriate conditions. Of course, coming of of the constriction, the velocity drops again, and the sensible enthalpy rises, so the condensate could evaporate again...
BBB
For water around its triple point (I guess for any other such substances too), it can actually not only condense but freeze.
This is why in aeroplanes there is a 'carburettor heater' so that you can make sure the venturi is warm. As you come into land on closed throttle when the manifold pressure is low, the additional venturi pressure drop is enough to cause condensation and freezing. Not what you want just at landing, in case you need to go around, so you get a little lever to push up as you come in on finals to heat the carb.
  • · Replies 48 ·
13K
