Can Intersecting Events in Probability be Independent?
The discussion centers on the independence of events A and B in probability theory, particularly when considering their intersections and unions. It is established that A and A∪B are independent if P(A∪B) equals 1, which is a special case of independent events. The conversation also highlights that having a non-empty intersection between A and B does not automatically imply dependence; proving independence requires additional numerical probability values. The participants emphasize the need to consider exceptional cases, such as when B is empty or when A and B do not overlap. Overall, the analysis points to the complexity of determining independence in intersecting events.
PFuser1232
##P(A|A∩B) = \frac{P(A∩(A∩B))}{P(A∩B)} = \frac{P(A∩B)}{P(A∩B)} = 1##
So given the the event "A and B" as the sample space, the probability of A occurring is 1.
##P(A|A∪B) = \frac{P(A∩(A∪B))}{P(A∪B)} = \frac{P(A)}{P(A∪B)}##
Those two events are independent if and only if the probability of "A or B" occurring is 1, in which case the conditional probability of A equals the probability of A.
Is my reasoning correct?
you mean that A and A∪B are independent if P(A∪B)=1 ? yes, this is a special case of independent events. There is one other special case which can mean that A and A∪B are independent. You are trying to make the last equation go from
P(A|A∪B) = \frac{P(A)}{P(A∪B)}
to become:
P(A|A∪B) = P(A)
right? and you did this by setting P(A∪B)=1. But there is another way also.
We'd have to consider the case B \cap A = \emptyset
Which two events? A and A \cup B ?
Suppose B = \emptyset.
I think your results are interesting and worth perfecting by taking care of the exceptional cases.
Stephen Tashi said:
We'd have to consider the case B \cap A = \emptysetWhich two events? A and A \cup B ?
What about ##P(A|B)##? My gut tells me that since A and B intersect, A and B must be dependent. This is wrong, of course, but how do I prove the dependence (or independence) of two intersecting events?
I don't know what your are asking.
You can't prove the dependence or independence of two events that have a non-empty intersection just from knowing the intersection is non-empty. It's a quantitative question that depends on the numerical values of the probabilities involved. If you want to prove a result, you'll have to add more assumptions - something beyond just knowing that the intersection is non-empty.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
