Conformal Spacetime: Paths of Photons & Massive Particles
  • Thread starter Thread starter wam_mi
    Spacetime
wam_mi
Dear all,
In flat conformal space-time,
e.g. \quad g_{\alpha \beta} = e^{4\kappa} \eta_{\alpha \beta}
where \kappa is some function of space-time coordinates.
What sort of paths do photons and massive particles follow? Could anyone describe their paths with some analagy or a picture? What is the difference between conformally flat space-time and flat space-time physically?
Moreover, if the space-time is only conformal but not flat, what does this mean physically? Why is conformal /conformal flat space-time useful in GR?
Coordinate transformations on spacetime are not conformal (angle preserving). Why would you think they are?
My understanding is:
Conformal transformations of the metric preserve the causal structure of spacetime, so the paths of light rays are unchanged. Conformally flat spaces will therefore have the same light cone structure as Minkowski space.
One of the reasons conformal transformations of spacetime are useful is to "bring in" infinity so that it can be represented on a diagram (Penrose diagram/Carter diagram or whatever), but the causal structure of the diagram is identical to that of the original spacetime.
This is correct.
wam_mi said:
Dear all,
Photons would simply have the same path as if they were to travel in a Minkowski spacetime. This can be easily proven in the metric you're giving as an example and I suppose you know how to prove it. But in case of massive particles, I have to prove how their paths undergo some change and in fact show how massive particles move along time-like curves. In the following, I take s to be the affine parameter of the time-like curves followed by particles and for simplicity I also take \kappa to be a function of the coordinate x in Cartesian coordinates x^{\alpha}:=(t,x,y,z). The line element is
ds^2=e^{4\kappa(x)}dt^2-e^{4\kappa(x)}(dx^2+dy^2+dz^2).
This can be written as
e^{-4\kappa}=\dot{t}^2-(\dot{x}^2+\dot{y}^2+\dot{z}^2),
where the overdots represent differentiation wrt s. Now working this into the Euler-Lagrangian equations gives the 4 geodesic equations:
\frac{d}{ds}(2\dot{t}e^{4\kappa})=0,
-\frac{d}{ds}(2\dot{x}e^{4\kappa})=4\frac{d\kappa}{ds}e^{4\kappa}[\dot{t}^2-(\dot{x}^2+\dot{y}^2+\dot{z}^2)]=4\frac{d\kappa}{ds},
-\frac{d}{ds}(2\dot{y}e^{4\kappa})=0,
-\frac{d}{ds}(2\dot{z}e^{4\kappa})=0.
Using \dot{\kappa}=\frac{d\kappa}{dt}\dot{t} the first of these 4 equations can be rewritten as
\ddot{t}+4\dot{t}\dot{x}\frac{d\kappa}{dt}=0. (*)
Now from this and that
\ddot{x}=\dot{\left(\frac{dx}{dt}\dot{t}\right)}=\ddot{t}\frac{dx}{dt}+\dot{\frac{dx}{dt}}\dot{t}=-4\dot{t}\dot{x}\frac{d\kappa}{dt}\frac{dx}{dt}+\dot{\frac{dx}{dt}}\dot{t}.
where we have made use of (*), the second of the geodesic equations can be cast into the following form:
\frac{d^2x}{dt^2}+2\frac{d\kappa}{dt}e^{-4\kappa}\dot{t}^{-2}=0. (**)
Integrating the time-related geodesic equation yields
\dot{t}=ae^{-4\kappa}
where a is the integration constant. Introducing this into (**) gives
\frac{d^2x}{dt^2}=-\frac{2}{a^2}\frac{d\kappa}{dt}e^{4\kappa}
which is the ultimate form of the second geodesic equation. The other two remaining equations are, in a somewhat similar way, found to be
\frac{d^2y}{dt^2}=\frac{d^2z}{dt^2}=0.
You can see that if \kappa=0 then all geodesic equations belong to the Minkowski metric. But since \kappa is a function of the coordinate x, among the spatial geodesic equations only the equation corresponding to the x component of the coordinate 3-acceleration has been modified and the other two are just the same as those of the Minkowski spacetime.
Considering pseudo-Riemannian, these are spacetimes that under a special condition can be mapped into flat spacetimes with metric components being -1 or +1 even though their Riemann tensor before mapping is not necessarily zero. The condition is that the vanishing of the Weyl tensor must be guaranteed for the spacetime to be conformally flat. In such spacetimes, all angles are preserved if the whole of spacetime (if the spacetime is conformally flat not locally conformally flat) gets mapped by a conformal transformation. One of the most significant class of conformally flat spacetimes is the constant-curvature class i.e. spacetimes with a constant curvature.
AB
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
