runicle said:
Okay can anyone tell me why is this true for restriction of 0 < x < 360
sin(x)=0.15, x = 8.6 and 171.4
cos(x)=-.655 x = 130 and 230
tan(x)=0.75, x = 36.9 and 216.9
I don't see a pattern or rule...
please co-ordinate me through the use of graphs if you can my teacher didn't explain it well.
The best way to understand *why* the signs (+ or -) of the trig ratios are the way they are in each quadrant is to plot curves like berkeman said.
But if you want a quick way to just remember it, this is what I use :
Just visualise the four quadrants : y and x-axes intersecting to give four square areas. The quadrants are labelled in a counter-clockwise fashion starting with the top right which is the first. Then the top left is the second, bottom left the third and the bottom right the fourth.
Think of the angles that bound each quadrant. Each quadrant spans 90 degrees or pi/2 radians. The angles go counterclockwise, just like the numbering of the quadrants. So the first stretches from zero to ninety degrees, second from 90 to 180 degrees, third from 180 to 270 and the fourth from 270 to 360 (which is also zero, since we've come a full circle).
Now, in your visualisation of the quadrants, firmly implant these letters in big bold print : A,S,T,C going counterclockwise. You can use some clever mnemonic to remember the order if you like. The A goes in the first quadrant and stands for "all" meaning all the ratios (sin, cos, tan) are positive in that quadrant. Similarly S means sine, telling you that only the sine is positive in the second quadrant and the tan and cos are negative there. You can work out the implications for the third and fourth quadrants.
So, when you're told :
"sin(x)=0.15, x = 8.6 and 171.4"
The sine is positive (0.15), so we're looking for an x in the first and second quadrants (A and S). The first value is the first quadrant value and the second is the 2nd quadrant value. Now, here's another thing to remember : if you treat the value of the trig ratio of an angle \theta as an unsigned number (don't care if it's positive or negative), you'll get the same absolute value (the same unsigned number) at \theta, 180 - \theta, 180 + \theta, 360 - \theta in degrees. This applies to all the ratios, and it's due to the periodicity of the graphs. The trick is to keep in mind which of those values (which lie in different quadrants) give you the correct sign of the ratio you're looking for. Example sin x = 0.5, which gives a first quadrant value for x as 30 degrees. Using this approach, you know you'll get the same value for |\sin x| for x = 30, 150, 210 and 330 degrees, which correspond to the four quadrants. However, since we want only values of x that give a positive sine, we only use x = 30 and x = 150 as solutions for our equation. (Try doing sin 210 and sin 330, you'll get -0.5 instead, see ?)
Use the same logic to figure these out :
"cos(x)=-.655 x = 130 and 230"
Here's a negative cosine value, so you're looking for quadrants where the cosine is NOT positive.
"tan(x)=0.75, x = 36.9 and 216.9"
