Confusing static equilibrium problem
The discussion revolves around a static equilibrium problem involving a 900-N boy on a ladder resting on a frictionless floor. The user successfully calculated the force exerted by the floor on each leg of the ladder as 225 N. However, they express confusion regarding how to determine the tension in the cross brace. A hint suggests considering the normal force and torque about the apex, as well as using trigonometry to find the length of the cross brace. The conversation emphasizes the importance of applying principles of static equilibrium and torque to solve the problem.
barnsworth
A 900-N boy sits on top of a ladder of negligible weight that rests on a frictionless floor as in http://m.domaindlx.com/barnsworth/physics.JPG. There is a cross brace halfway up the ladder, and the angle at the apex is 30 degrees.
a) What is the force exerted by floor on each leg of the ladder?
b) Find tension in the cross brace.
The first part was simple enough i guess. i did 4F = 900 since net Fy = 0, giving me F = 225 for (a).
Haven't the slightest clue on part (b) though. I don't know where to begin. :cry:
Anyways, thanks for any help in advance.
Hint: The floor exerts a normal force upwards, which creates a torque about the apex.
Also, you can calculate the length of the cross Brace using trigoniometry...
then apply the nice hint of Galileo when calculating the torque...
regards
marlon
