I Confusion about initial states and coherent states
valanna
I've found online that the coherent state of the harmonic oscillator is
|\alpha \rangle = c \sum_{n=0}^\infty \frac{\alpha^n}{\sqrt{n!}} | n\rangle
where
|n\rangle = \frac{(a^\dagger)^n}{\sqrt{n!}} |0\rangle
and |0> is called the initial state.
I've some code where I need to have this initial state for j=4, so it should be a 9 by 1 vector right?
How is this initial state found?
Harmonic oscillators need an infinite dimensional Hilbert space, 9 dimensions do no suffice. The formula you wrote is for unpolarized light. In the case of polarization (where j makes sense) you need a Fock space over a 2-mode 1-particle Hilbert space, and the formula gets more complicated.
Likes valanna
So the |0> is in Hilbert space? If there were a coherent state that was in a space where j=4, is there a method to find |0>?
##|0\rangle## is the ground state (no oscillation, e.g., no light) of a harmonic oscillator Hamiltonian, in the space ##L^2(\Rz)## (or the equivalent Fock space).
What do you mean by this? A 1-particle space with angular momentum 4 but position and momentum ignored? In this case, the appropriate coherent states are very different - you need angular momentum coherent states.
Likes valanna
Thank you, Those are what I'm looking at, I suppose I made the mistake in thinking the coherent state for the harmonic oscillator was the same because its equation is a similar format to the one I'm looking at.
The main difference is that the state I need to find is represented by |j,j> but I'm having trouble finding how that state is actually found. I see it used or similar states used but no value or formula is ever given. Is it something trivial I'm just missing or does it have no actual value?
Thank you very much for your help
where
##|0 \rangle## is not an arbitrary initial state but the ground state of the harmonic oscillator. It's just defined by ##\hat{a}|0 \rangle=0##. It's of course also a coherent state with ##\alpha=0##.
The initial state of a quantum system can be anything. It's determined by the preparation of the system at the initial time.
Likes valanna
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
