Confusion about the interpretation of specific volume
The discussion revolves around the interpretation of specific volume in thermodynamics, particularly in the context of a tank containing a liquid and vapor mixture. Participants explore the implications of specific volume calculations when determining the state of a substance, focusing on whether the tank is fully filled with liquid or contains a mixture.
  • Some participants question whether the pressure referred to in examples is vapor pressure, given the context of pure substances.
  • There is confusion about the assumption that the liquid fills the tank, with some arguing that it is not clearly stated in the examples.
  • Participants discuss the implications of dividing the volume of the vessel by the mass of the liquid, suggesting that this approach may not accurately reflect the state of the liquid if it does not occupy the entire volume.
  • One participant proposes that if the mass of refrigerant is insufficient to fill the tank, a mixture of liquid and vapor must exist, leading to a different interpretation of specific volume.
  • There are differing views on whether the specific volume of a compressed liquid can be determined accurately without knowing the volume of the liquid itself.
  • Some participants assert that if the liquid is compressed, the specific volume should be less than that of the saturated liquid, while others challenge this reasoning by considering the relationship between the volumes of the compressed liquid and the tank.
Participants express various viewpoints, and no consensus is reached regarding the assumptions about the tank's contents or the implications of specific volume calculations. The discussion remains unresolved with competing interpretations of the examples presented.
Participants highlight potential limitations in the examples, such as missing assumptions about the tank being filled with liquid and the dependence on definitions of specific volume. There are unresolved mathematical steps regarding the relationship between the volumes of the liquid and the tank.
EddiePhys
So I'm reading through Cengel's thermodynamics textbook, and came across this solved example:
Firstly, pressure in this context I'm assuming is vapour pressure? Since we're dealing with pure substances in this chapter.
But what's confusing me is, here's the diagram I have:
They've not mentioned that the water fills the tank. So I don't understand why the specific volume times the mass of the water equals the volume of the tank?
They've used similar reasoning in following solved examples as well where it's unclear that the liquid will occupy the tank volume
Science news on Phys.org
I think you can safely take it that there is nothing else present, i.e. no water vapour...
They have used similar lines of reasoning in future solved examples where it's not so clear that the tank will be filled with liquid
For example, here, when they compare the ##v## value with ##v_g## and ##v_f##, to determine the state, it would only make sense if, when it is in liquid state, it is occupying the entire vessel:
I guess you weren't satisfied with my answers in that other forum.
Yes, there is a subtle difference between "4 kg of refrigerant" and "50 kg of saturated liquid water" .
You'd better learn to distinguish the difference in these simple exercises -- practice for later when it's not so easy any more. :wink:
I really appreciated your answers. Something just wasn't clicking with me. So I thought getting different perspectives would perhaps help. Please don't take it personally, I really do appreciate your help.
The largest volume that 4 kg of refrigerant 134a can occupy as a liquid at 160 kPa is (0.0007435)(4)=0.0030 m^3 = 3.0 liters
Yes. So what I'm not getting is why they're dividing the volume of the vessel by 4kg. They're then comparing this value with 0.0007435. The two would only be equal if they were the volume of the liquid by 4kg (or equivalently, that the vessel was fully filled, in which case dividing the volume of the vessel by 4kg is the same as dividing the volume of the liquid).
So in the case that the liquid only occupies a small portion of the volume of the vessel, volume of the vessel divided by 4kg would not be suitable means to assess if it's in compressed liquid state
The mass of refrigerant is way less than sufficient to fill the tank with liquid alone.. So there must be mixture of liquid and vapor in the tank. At equilibrium, we must have that : $$m_Lv_L+m_Vv_V=V$$Doo you agree with this?
This would mean that it can't be in a state of compressed liquid (i.e., liquid at a pressure greater than the vapor pressure at the tank temperature).
Yes, agreed with the first part. And this would hold even for the compressed liquid state, correct?
The second part, what I'm thinking is: imagine a piston pushing down on a liquid contained in a cylinder with some pressure. This compresses the liquid. So wouldn't the the specific volume for a given pressure be equal to the volume of this liquid divided by the mass. And this would be the value reported in tables.
In our case we're dividing the volume of an arbitrary vessel by the mass of the liquid and comparing it to the above value.
Yes, reported in tables for compressed liquid.
The value we calculate is between that of a saturated liquid at 160 kPa and a saturated vapor at 160 kPa. So we must have a combination of the two.
But even if it was a compressed liquid, we wouldn't know because we're not dividing the volume of the liquid by its mass, and this is the value that is given in tables and that we're using as a standard for comparison.
If it was a compressed liquid, the tank volume divided by the msss of refrigerant in tank would be less than the specific volume of the saturated liquid.
Why though. Let's say V1 is the volume of the compressed liquid and V2 the tank. And V2>>V1. In this case, the specific volume of the compressed liquid would be calculated V1/M in the tables while a saturated liquid at that pressure might have a volume in the vicinity of V1, let's say V1 plus a since liquids aren't that compressible. But we're calculating it as V2/M and V2>>V1, so it why shouldn't the tank volume give the larger answer
If it is "compressed liquid," then there is no vapor in the tank, and ##V_1=V_2##. In this case, $$\frac{V_1}{M}=\frac{V_2}{M}<v_L(T)$$where ##v_L(T)## is the specific volume of saturated liquid at the tank contents temperature T. So the specific volume is a little less than the specific volume of the saturated liquid, and the tank is filled with liquid if the pressure is above the saturation vapor pressure at T.
Okay I think now I am close to getting it. What would the case then be where V1 << V2 AND there's no vapor in the tank? Or is this a case we simply don't consider. So we only have 1) tank full of liquid,2) liquid + gas, 3) only gas as possibilities. And if I understand correctly, saturated liquid is almost like (1) i.e fully filled tank but slightly larger volume
If there is no vapor in the tank, then ##V_1=V_2##
Yes.
EddiePhys said:
And if I understand correctly, saturated liquid is almost like (1) but a tiny portion is gas
Purely saturated liquid is like (1) but with essentially no vapor.
Yes.
"If there's no vapor in the tank, then ##V_1=V_2##" So you can't simply have a liquid with a volume less than the tank volume. The second you do, you are in the region to the right of the saturated liquid phase (i.e saturated liquid-gas mixture)
I'm taking you liking the post to mean yes. In which case, I think I got it! Head's a bit hazy right now so I'll know for sure by tomorrow morning, but thank you so much!! I really appreciate you taking the time you did to answer my questions
  • · Replies 0 ·
  • · Replies 27 ·
