Connect these three: Drain, Stem, Stew.
  • Thread starter Greg Bernhardt
  • Tags
    Stem
In summary, the words drain, stem, and stew are connected by a common meaning of removing or extracting something. From a scientific perspective, they are connected by the process of osmosis. There is also a linguistic connection between these words, as they all share the same root word. These words are used in various contexts, such as plumbing, horticulture, and cooking. There are also idiomatic expressions that use these words.
10,021
They all deal with liquids
Drain - Emptying of liquids
Stem - Flow of liquids
Stew - Made with liquids
Brain:
Brain Drain, a term given to the migration of intellectuals from one country to another.
Brain Stem: A part of the brain.
Brain Stew: Music by Green Day?
Each word could relate to the word 'slow'.
Drain: To draw off a liquid slowly.
Stem: To slow down
Stew: To cook slowly.
FZ+ wins the point!
1. How are drain, stem, and stew connected?
These three words are connected by a common meaning of removing or extracting something. Drain refers to removing liquid, stem refers to removing the stem of a plant, and stew refers to extracting flavor from ingredients by cooking in liquid.
2. What is the scientific explanation for the connection between drain, stem, and stew?
From a scientific perspective, drain, stem, and stew are connected by the process of osmosis. This is the movement of liquid through a semi-permeable membrane, such as the skin of a plant or the cell walls of ingredients in a stew, in order to reach an equilibrium. In the case of drain, the liquid is being removed from a container, while in the case of stew, the liquid is being absorbed by the ingredients.
3. Is there a linguistic connection between drain, stem, and stew?
Yes, there is a linguistic connection between these three words. They all have origins in Old English and share the same root word "drian", which means to filter or strain. This root word evolved into "drain" and "stew" in the modern English language, while "stem" comes from the Old Norse word "staf", meaning a staff or rod used for support.
4. Can you provide examples of how drain, stem, and stew are used in different contexts?
Sure, "drain" can be used in a plumbing context, such as "the sink is clogged, we need to drain it." "Stem" can be used in a horticulture context, such as "I need to cut the stems of these flowers before putting them in a vase." "Stew" can be used in a culinary context, such as "I'm going to stew these vegetables to make a flavorful broth."
5. Are there any idiomatic expressions that use drain, stem, or stew?
Yes, there are several idiomatic expressions that use these words. "Drain the swamp" means to get rid of corruption or problems in a particular situation. "Stem the tide" means to stop or slow down a trend or force. "Stew in your own juices" means to suffer the consequences of your own actions.
  • General Discussion
  • STEM Academic Advising
