Connecting two circuits with a single conductor
  • Thread starter Thread starter TheCanadian
    Circuits Conductor
Connecting two independent circuits with a single conductor at arbitrary voltages will lead to an attempt to equalize the potential at the connection points. Initially, there may be no current flow if the circuits are at different voltages, but this can change depending on the specifics of the circuits involved. If one circuit has an existing current, the connection could alter that current unless the points are at equal potential. The situation varies if the circuits are earthed, as this can change voltages and currents due to shared reference points. Additionally, some current may flow through the connecting wire if the circuits possess capacitance that completes the circuit.
TheCanadian
If you have two independent circuits, and then connect them at two points that are at arbitrary voltages by a single conductor, what happens to the system? A moment after the connection happens, I would assume there to be no current between the circuits since the two circuits would try and establish equal potential at the two points they're connected by, right? But would that actually happen? If you had a current I1 going through one of the circuits for example, and then connected the two circuits together by this one conductor, would I1 change at that instant (unless the two points the conductor is connected to is at equal potential)?
It may definitely change the currents and voltages in both circuits. In what way will depend on the specifics.
The potential is defined with respect to a given point. If two circuits have only a single point in common that point can be considered as the zero of potential for both of them. All the voltages (potential differences) are the same as before they get connected.
The situation is different if the circuits are earthed. In this case, connecting them changes the voltages and currents, as they got two points in common, unless the points were at the same potential with respect to the ground.
What ehild said.
There might be some current flow in the single the connecting wire if the "independent" circuits actually have some capacitance that completes the circuit.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
