Cons of Stopping shaft connected to gearbox
  • Thread starter Thread starter chintu
    Shaft
The discussion centers on the feasibility of using a gearbox and induction generator to convert intermittent rotational energy from a shaft into electricity. The gearbox is primarily for adjusting speed, but the intermittent nature of the shaft's rotation (1 minute on, 10 seconds off) raises concerns about the generator's ability to produce consistent output. Storing the generated electricity in batteries or capacitors is suggested to manage the irregular power supply. Asynchronous generators may not be ideal for standalone systems, with alternatives like DC or permanent magnet machines being recommended. The overall solution depends on specific goals, including power ratings and cost considerations.
chintu
Hi,
I'm new to this field. I'm interested in knowing electrical motor/generator operations. I have few questions here could you please help me. Qtn: I have a shaft rotating a minute and not rotating 10 seconds. i.e 1min rotates + 10sec stopped + 1min rotates + 10...and so on. In this case does gear box provides constant output? or does gear box needs continuous rotating shaft? what are the cons if the shaft stops like this?
Thanks a million in advance!
I don't understand what you mean, so you have to elaborate some more.
What is the prime mover of the shaft? What is it connected to? Why do you need a gear box? Do you need to break the shaft every 1 minute? Do you want to generate electricity from the rotating/kinetic energy stored in the shaft?
Thank you very much for the quick reply!
Yes, shaft is connected to a rotating object which stops every minute and starts after 10seconds. So I want to connect gearbox and then to induction generator for electricity.
What about a clutch?
Thanks again!
As I'm new to this field, I do not know much about components. Please don't mind sharing your views. I will put my question in other way. I have a mean(external process) which rotates a shaft/rod for a minute and stops 10secs and again rotates 1 minutes and so on. I want to convert this kinetic energy into electricity by attaching an asynchronous induction generator. Is it possible? If yes could you please give me what are the components that I need to add in between my shaft and generator? If not why? Does induction generator accepts breakdowns(10sec) of rotating shaft? If not, is it possible to convert this broken rotations into continuous rotation(to feed to generator)?
thanks a million in advance!
First of all, a gearbox only changes the speed. So to determine if you need one you have to look at the shaft rotation speed in relation to the generator nominal speed.
Problem is what are you going to do with the electricity produced. It is intermittent so you may want to store it in a battery/capacitor or something for continuous output power. Or is it going to be connected to the power grid?
Asynchronous generators are difficult to run in a stand alone system. A DC / permanent magnet machine may be easier to implement if this is the case.
There are a lot of possibilities, both electrical and mechanical solutions but it really depends on what you want to achieve, power ratings, cost, lifetime etc.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
