Cons of Stopping shaft connected to gearbox
  • Thread starter Thread starter chintu
    Shaft
The discussion centers on the feasibility of using a gearbox and induction generator to convert intermittent rotational energy from a shaft into electricity. The gearbox is primarily for adjusting speed, but the intermittent nature of the shaft's rotation (1 minute on, 10 seconds off) raises concerns about the generator's ability to produce consistent output. Storing the generated electricity in batteries or capacitors is suggested to manage the irregular power supply. Asynchronous generators may not be ideal for standalone systems, with alternatives like DC or permanent magnet machines being recommended. The overall solution depends on specific goals, including power ratings and cost considerations.
chintu
Hi,
I'm new to this field. I'm interested in knowing electrical motor/generator operations. I have few questions here could you please help me. Qtn: I have a shaft rotating a minute and not rotating 10 seconds. i.e 1min rotates + 10sec stopped + 1min rotates + 10...and so on. In this case does gear box provides constant output? or does gear box needs continuous rotating shaft? what are the cons if the shaft stops like this?
Thanks a million in advance!
I don't understand what you mean, so you have to elaborate some more.
What is the prime mover of the shaft? What is it connected to? Why do you need a gear box? Do you need to break the shaft every 1 minute? Do you want to generate electricity from the rotating/kinetic energy stored in the shaft?
Thank you very much for the quick reply!
Yes, shaft is connected to a rotating object which stops every minute and starts after 10seconds. So I want to connect gearbox and then to induction generator for electricity.
What about a clutch?
Thanks again!
As I'm new to this field, I do not know much about components. Please don't mind sharing your views. I will put my question in other way. I have a mean(external process) which rotates a shaft/rod for a minute and stops 10secs and again rotates 1 minutes and so on. I want to convert this kinetic energy into electricity by attaching an asynchronous induction generator. Is it possible? If yes could you please give me what are the components that I need to add in between my shaft and generator? If not why? Does induction generator accepts breakdowns(10sec) of rotating shaft? If not, is it possible to convert this broken rotations into continuous rotation(to feed to generator)?
thanks a million in advance!
First of all, a gearbox only changes the speed. So to determine if you need one you have to look at the shaft rotation speed in relation to the generator nominal speed.
Problem is what are you going to do with the electricity produced. It is intermittent so you may want to store it in a battery/capacitor or something for continuous output power. Or is it going to be connected to the power grid?
Asynchronous generators are difficult to run in a stand alone system. A DC / permanent magnet machine may be easier to implement if this is the case.
There are a lot of possibilities, both electrical and mechanical solutions but it really depends on what you want to achieve, power ratings, cost, lifetime etc.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
