Conservation of Angular momentum problem
The discussion focuses on solving a conservation of angular momentum problem involving a block sliding down a frictionless surface and colliding with a vertical rod. Participants analyze the angular momentum before and after the collision, emphasizing that the angular acceleration is not constant due to the changing tangential force from gravity as the rod pivots. They derive expressions for angular momentum and angular velocity, ultimately aiming to find the angle θ that the rod reaches after the collision. The importance of using conservation laws correctly is highlighted, particularly in accounting for the combined moment of inertia of the rod and block system. The conversation concludes with participants refining their calculations and understanding of the moment of inertia in the context of the problem.
i_hate_math
In the figure, a small 0.235 kg block slides down a frictionless surface through height h = 0.471 m and then sticks to a uniform vertical rod of mass M = 0.470 kg and length d = 2.36 m. The rod pivots about point Othrough angle θ before momentarily stopping. Find θ.
L=I*w
P=mv
v=wr
Ki=Kf -----> 0.5mv^2=mgh , and this gives expression for 'v'
w^2=w0^2 + 2*alpha*(delta ø) , for when alpha(angular acceleration) is constant
in effort to find ø, alpha and w are needed. I established that m*v=I*w (not sure if this is correct)
by substituting relevant equations, i got w0=[sqrt(2gh)]/d^2
and w, is according to the question, 0.
now i can't seem to find an expression for alpha.
could u point out what i missed out?
Find out angular momentum of the system just after impact. Just before the impact the angular momentum is non-zero only for the hitting block given by mvr*L about the pivot, which moment of momentum. Assume some instantaneous velocity V for the hit tip of the rod, which will be the same for the block too just after it sticks.. Your equation is wrong even dimension-ally.
But it won't be.
Because alpha is not constant you cannot apply that formula. Apply Total L conservation just before and after impact and for rest segments apply energy conservation.
I've reworked an expression for w, w=sqrt(2gh)/3d
by applying I*w = I*w
but then how do i find the angle?
i_hate_math said:
sqrt(2gh)/3d
I don't understand how you get that. Please post your working.
why isn't alpha constant?
What force is responsible for the angular acceleration? Is its moment about the centre of the arc constant?
Oh I get it thanks a lot.
Is it because gravity causes the tangential force to change when the rod pivots which causes the angular acceleration to change?
Yes, as the angle changes the tangential component of gravity changes.
Because Torque acting on the bar and the attached piece is not constant.
Right before the cube collied with the rod, it's angular moment is I*w=1/3md^2 * (v/d), where v=(2gh)^0.5
right after the collision, the new I*w=1/3(m+M)d^2 * w
now that I*w=I*w, we have new w=(mv)/(m+M)d=(1/3)(v/d)=sqrt(2gh)/3d
It is described as small, so consider it a point particle. Where do you get the 1/3 from?
m/(m+M)=0.235/(0.235+0.47)=1/3
I still don't get it. You wrote
i_hate_math said:
Right before the cube collided with the rod, it's angular moment is
so we're talking about the angular momentum of the small block. It has not hit the rod yet, so M cannot play a role.
I assumed it could as suggested by the other guy
If this does not hold, which equation shall I establish?
Do you mean this:
If so, you are misreading it. The expression for the angular momentum of the block just before impact is clearly stated there. But the first part, "Find out angular momentum of the system just after impact." may be slightly misleading. Let'sthink means the angular momentum of block+rod just after impact (and this does involve M) is equal to that of the block just before impact. So you need two expressions for angular momentum, one just before impact and one just after, which you then set equal to obtain an equation.
You do not need to worry about forces and accelerations. Just use conservation laws as appropriate. After impact, what is conserved?
haruspex said:
Do you mean this:
So the angular momentum of the small block would be I*w of the slide-block system, I=(1/3)mh^2, w=v/r
Forget the rod for the moment. We have a small block which has reached a speed of √(2gh) and is traveling horizontally at a distance d below point O. What is the angular momentum of the block about point O? If you think there is a factor 1/3 in the answer, please explain how you arrive at that.
Oh right, so L=r*p where p=m*v, thus L=r*m*v=h*sqrt(mgh)*m
i_hate_math said:
r*m*v=h*sqrt(mgh)*m
Too many h's, too many m's. What is r here? Is one of the m's a typo?
soz, r=h v=sqrt(mgh) and the block has mass m.
thus L=r*p=rmv=h*m*sqrt(mgh)
i_hate_math said:
r=h
Wrong.
i_hate_math said:
v=sqrt(mgh)
Wrong again (even, dimensionally wrong).
haruspex said:
Wrong.
v=sqrt(2gh). but why isn't r=h?
Because we're discussing the angular momentum about point O, i.e. the top of the rod. How the particle came to be traveling horizontally at this speed is no longer of interest, so h plays no further part (beyond determining the speed).
shall i replace h with d?
Yes.
haruspex said:
Yes.
okay, then I have w=sqrt(mgh)/d
could u suggest a way to find the angle ø?(I haven't learned this chapter of physics course yet, limited knowlege)
No. Reread your own post #24.
Reread the last lines of posts #4 and #17.
w=sqrt(2gh)/d
use energy conservation, so delta(GPE)=1/2Iw^2?
  • #31
i_hate_math said:
w=sqrt(2gh)/d
Right. The final challenges are to calculate I correctly for the rod plus block, and express the ΔGPE as a function of the angle.
  • #32
okay,
now w=sqrt(mgh)/d
mgl=0.5Iw^2, where l is change in height
and by subing in all the mess l=h
and then ø=arccos[(d-h)/d]=36.8
  • #33
i_hate_math said:
okay,
now w=sqrt(mgh)/d
soz w=sqrt(2gh)/d i meant
  • #34
l is not equal to h
  • #35
kinemath said:
l is not equal to h
I mean after subing in all the values, i got l=h, or did i do the wrong calculations?
  • #36
is h the original height and l the final height?
  • #37
How did you get l=h?
  • #38
L=(0.5I*w^2)/mg
  • #39
Hmm... I don't think energy is conserved as it is an inelastic collision.
  • #40
After the collison, mechanical energy is conserved
  • #41
i_hate_math said:
now w=sqrt(2gh)/d
Right, though we will have to be careful not to confuse l (lower case L,)with I (uppercase I). To avoid confusion I'll write H for the change in height and Imom for moment of inertia. Also, the m in there should be for the mass of the rod plus block, not just the block, and H is the change in height of the mass centre of that combination. We will return to that later.
As I said, you next need to figure out the right value for Imom. This is for the rod and block as a combined system. Think carefully.
  • #42
Since the block is treated as a particle, the Imom would be 1/3mw^2 right?
  • #43
(1/3)(m+M)w^2 is what i meant.
  • #44
Let ω be the instantaneous angular velocity of the rod as well as the stuck block about the pivot just after impact.
Te expression for angular momentum of rod + block just after impact {(Md²/3) + (md²)}ω. Equating this with initial angular momentum of the block just before impact gives you ω
To find θ, find the change in potential energy of the rod and the stuck block, when the rod reaches the angle θ and momentarily come to rest. This then is ro be equated with initial rotational KE of the of the block using formula 0.5Iω², where I = {(M/3)+m}d². { Note I(rod) = M(d²/3) and that of stuck small block = md²}
Likes i_hate_math
  • #45
First, you don't mean w2, I hope. A moment of inertia is a mass multiplied by the square of a distance.
Secondly, you need to consider each body separately and add up their moments. What did you find for the moment of the block about O in post #26?
  • #46
Please do not spoon-feed @i_hate_math. He/she needs to get the hang of figuring these things out.
  • #47
Yeah i didnt. I think i know where i went wrong. Its MoI again, nasty little bugger, the MoI of a point is simply md^2, and i forgot to add this into my calculation.
