Conservation of Angular Momentum
The discussion focuses on a physics problem involving the conservation of angular momentum for a spinning merry-go-round with two children. The initial setup involves calculating the new rotation rate after a second child jumps on. The equation I1ω1=I2ω2 is correctly applied, but initial angular velocity must be converted from revolutions per second to radians per second for accurate calculations. After addressing the setup and ensuring all variables are included, the calculated new rotation rate is confirmed to be 0.214 rev/s. The importance of unit conversion and thorough variable inclusion is emphasized in solving such problems.
icf927
A solid cylinder merry-go-round of mass 250kg and radius of 1.9m spinning at 1 revolution every 5 seconds has a 40kg child sitting at 1.1m from the axis. A 50kg child, running tangentially at 3m/s, jumps on the merry go round at the outer edge. What is the new rotation rate in rev/s?
I1ω1=I2ω2
(1/2MR^2 +m1r^2)ω1 + (m2r^2)(v/r)=(1/2MR^2 +m1r^2 +m2r^2)ω2
I plugged in all the variables and solved for ω2 and got 0.214 rev/s. Did I set up the equation correctly and come about the right answer?
The radii are different for the children.
ehild
yes I plugged in the different radii. I just forgot to put a 1 and 2 behind them in the equations.
Could you please show your calculations in detail?
ehild
(1/2(250kg)(1.9m)^2)(1.256637061rad/s)+((50kg)(1.9m)^2(3m/s/1.9m)=(1/2(250kg)(1.9m)^2+(40kg)(1.1m)^2+(50kg)(1.9m)^2)w2.
solved for angular velocity(w2) and got 0.214rev/s. is this the right set up?
You left out the first child on the left hand side.
ehild
I did it on paper just forgot to type it on here. When I include the first child on the left hand side, is that the right setup?
It is, but I got different result. Show calculations in detail.
ehild
Did you change the initial angular velocity from revolution/sec to rad/sec and then change the final answer back to revolutions/sec
Ops! You are right. I calculated w. So your result is correct.
ehild
