Conservation of energy and momentum transfer
In a discussion about the conservation of energy and momentum during a tennis ball's collision with a wall, participants clarified that while momentum conservation applies, the assumption of unchanged ball speed post-collision is flawed. The wall, having a finite mass, would indeed move slightly, taking some kinetic energy from the ball, resulting in a lower speed for the ball after the impact. The conversation also touched on the nature of elastic collisions, emphasizing that total kinetic energy remains constant, but not necessarily for each object involved. Additionally, the behavior of photons upon reflection was examined, confirming that their speed remains unchanged while momentum conservation still holds. The discussion concluded with references to Compton scattering as a relevant example of energy and momentum conservation in particle interactions.
DoobleD
Let's say a tennis ball with velocity with only an horizontal component hits a vertical wall at rest.
After collision, conservation of momentum tells that :
m_{wall}v_{wall} = 2m_{ball}v_{ball}
Thus, the wall has now a (tiny) velocity and kinetic energy :
v_{wall} = \frac{2m_{ball}v_{ball}}{m_{wall}} , K_{wall} = \frac{2m_{ball}^2v_{ball}^2}{m_{wall}}
while the kinetic energy of the ball didn't change. Where does the "new" energy in the wall come from ?
This is not true. If the wall has a finite mass (if not, that equation does not make sense), the ball will be slower after the collision.
Likes DoobleD
You merely assumed that the final speed of the ball equals its initial speed. A good approximation, but an approximation nonetheless. In reality, it slows down.
Also realize that the wall is most likely attached to something (the ground, for instance) making its effective mass much larger (>>) than that of the ball.
(Edit: I see mfb making the same statement.)
Thank you guys for answering. So you tell me a purely elastic collision in such a case is not physical, all right. Are there some conditions where purely ellastic collision is possible ? Or would it be a violation of conservation of energy (assuming no object can have an infinite mass...not sure this applies to black holes though...) ?
Or maybe 100% reflection of light ? Is a 100% reflecting mirror physical ? Actually I was initially trying to understand why a 100% reflected beam of light on a mirror doesn't transfer energy to it.
The issue here is not one of elastic vs inelastic collision. You can assume a perfectly elastic collision. (Unrealistic, of course, but why not?) That just means that the total KE will remain the same. If the wall moves, it takes with it some of that KE, leaving less for the ball. (Just depends on how exactly you want to calculate things.)
But if the wall takes some of the KE of the ball with it, doesn't that imply that the speed of the ball after the collision is less than before the collision ? Thus implying a partially elastic collision only?
Actually either the speed of the ball is less, or its mass. But that doesn't sound like something physical either.
A perfectly elastic collision is where the total KE remains the same. Not the KE of each participant separately.
Likes DoobleD
Oh, right ! Big mistake for me there, thank you.
Just a small side-remark:
Black holes have a finite mass.
Likes DoobleD
Thanks for the precision. As I don't know anything about GR, I won't ask further questions regarding black holes. :D
Concerning photons "bouncing" off a mirror, is it safe to assume their speed after collision is the same as before ? Not sure how this agrees with momentum conservation though, since I have heard photons have no "rest" mass. Probably too much out of classical physics knowledge as well?
EDIT : ahhh yes I recall black holes have infinite density, not mass!
Yes.
For a photon, p = E/c.
An example of energy and momentum conservation involving photons that is commonly studied at the introductory undergraduate level, is Compton scattering. An incoming photon scatters off a stationary electron, and the two particles recoil in different directions.
https://en.wikipedia.org/wiki/Compton_scattering#Derivation_of_the_scattering_formula
Note that we have to use relativistic equations for energy and momentum, not classical.
Likes DoobleD
Thank you !
