Conservation of Energy cannonball
The discussion focuses on calculating the maximum height and total mechanical energy of two cannonballs fired at different angles using conservation of energy principles. The first cannonball is fired at a 42-degree angle, while the second is fired straight up at 90 degrees. At maximum height, the kinetic energy of both balls is converted entirely into potential energy. To find the maximum height for the angled cannonball, the vertical component of its initial velocity must be determined. Understanding these concepts is essential for solving the problem accurately, particularly how to apply the conservation of energy equation.
jmwachtel
A 20.0 kg cannonball is fired from a cannon with a muzzle speed of 1050 m/s at an angle of 42.0° with the horizontal. A second ball is fired at an angle of 90.0°.
(a) Use the isolated system model to find the maximum height reached by each ball.
(b) What is the total mechanical energy of the ball-Earth system at the maximum height for each ball? Let y = 0 at the cannon.
Ei = Ef
K = (1/2)mv^2
U = mgy
I know that you can solve for h by setting these two equal, but I don't understand why that works. I need to understand how these relate. I have no idea what to do for b. Thank You.
The total mechanical energy of the ball at any point is going to be its kinetic energy + potential energy, and we're going to say the ground has gravitational potential energy of 0
So when either ball is first fired it's at a height of 0, so they have 0 initial potential energy, all they have is kinetic.
At their maximum height their velocities are 0, so they have no kinetic energy, instead all they have is potential. Because of conservation of energy(and because we're ignoring air resistance and all that), ALL that initial kinetic energy was converted to potential, and though the problem doesn't deal with it, the ball is going to fall and all that potential energy is going to get turned back into kinetic, and the total amount never changes
Also keep in mind for the first ball that it's fired at an angle, and you're only concerned with height in this problem, so you need to find the velocity in the vertical direction
How do you find velocity in the vertical direction?
I see on the 2nd ball that is fired the potential energy is 1.10e7 which is just mgy. How is the 1st ball calculated? I guess that's where I am having the most problem with that angle. Is it still just mgy?
average velocity:
LaTeX graphic is being generated. Reload this page in a moment.
yes your on the right tracks
So for the 90 degree ball you just took its initial velocity(which was all vertical since it was at 90 degrees) and found the initial kinetic energy, and knew that was how much potential energy it'd have at the peak
For the other ball you do the exact same thing, but it'll have a different initial velocity in the y direction. You're on an energy unit so you've done projectile motion, which means you've found initial vertical(and horizontal though you don't need it here)velocities given initial velocity and an angle about 44594895709 times. Don't overthink it
Ok, so I would use mg (Vsin(42))?
Is this correct?
Why would you want m*g*Vyi?
so I should be looking for mg*Vyxi?
Well what good is mgVanything to you? That's almost your equation for potential energy
You CAN use that velocity to find initial kinetic energy though. Then you can use potential energy to find distance
Well I am looking for the potential energy of the 1st ball on part b which has the 42 degree angle. All of the energy is still potential right?
I'm still lost?
Well eventually, but initially all it has is kinetic
Ok, then what do I need to solve the problem? Does the angle matter?
