Conservation of energy/momentum and difference reference frames
The discussion explores a thought experiment involving a spaceship using mechanical springs for thrust, highlighting the confusion around energy and momentum conservation in different reference frames. When the spaceship fires springs in a stationary frame, it appears to gain velocity with each firing, suggesting an unrealistic increase in speed. The analysis reveals that the mass of the balls must be considered to accurately apply conservation laws, as the energy transferred to the balls affects the overall system. The relationship between the ship's mass and the balls' mass significantly influences the kinetic energy distribution. Ultimately, understanding these dynamics is crucial for correctly applying the principles of conservation of energy and momentum.
fulis
I managed to confuse myself with a simple thought experiment.
I have a spaceship that uses mechanical springs loaded with balls for thrust. We start in a reference frame O where the ship isn't moving and fire one spring, which gives the ship a velocity v. Pick a new frame O', moving at v in the same direction, so the ship appears static again and fire another spring. If the mass of each ball is small in comparison to the ship, every repetition of this is the same, so the ship appears to increase its velocity by v each time a spring is fired. This doesn't make sense though, because let's say I fired 10 springs, then by tracing back to the original frame O the ship would appear to be moving at 10v. However, each spring is identical so it should store the same energy. Obviously E=M/2 * (10v)^2 != M/2 * 10 * v^2.
If the ship is much heavier than the balls, then most of the energy stored in the springs is going to go to accelerating the balls. You must include the balls into your analysis in order to be able to use conservation of energy.
Example: For the firing of one ball at rest with ball mass m and ship mass M, conservation of momentum yields mv = - MV where v is the velocity of the ball and V that of the ship. As a result
v = -\frac{MV}m \quad \Rightarrow \quad \frac{mv^2}2 = m\frac{M^2V^2}{2m^2} = \frac{M}{m} \frac{M V^2}2,
so the ball kinetic energy will be a factor ##M/m## larger than the ship kinetic energy.
Thank you :)
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
