Conservation of energy with spring
A spring with a constant of 22 N/m is compressed by a 0.4 kg mass and released, skidding over a frictional surface before compressing a second spring with a constant of 2 N/cm. The frictional surface has a coefficient of 0.17 and a length of 2.3 m, with gravity at 9.8 m/s². The discussion involves applying energy conservation principles and work-energy equations to determine how far the second spring will compress to stop the mass. Key formulas mentioned include work done by non-conservative forces and energy conservation equations. The challenge lies in correctly incorporating the effects of friction into the calculations.
fanie1031
1. A spring of constant 22 N/m is compressed a distance 8 cm by a 0.4kg mass, then released. It skids over a frictional surface of length 2.3m with coefficient of friction 0.17, then compresses the second spring of constant 2N/cm. The acceleration of gravity is 9.8m/s(squared). How far will the second spring cmpress in order to bring the mass to a stop? Answer in cm.
2.
W=Fd
.5mgyf + .5Kdelta(X squared) = .5mgyo + .5Kdelta(Xsquared)
also mgyf + 1/2mVf^2 = mgyo + 1/2mVo^2
3. I used all three formulas but the fact that I'm using cefficients is throwing me off.
Hi fanie1031,
2.
W=Fd
For consant forces the work done is:
<br /> W=F d \cos\theta<br />
where theta is the angle between the force and the displacement of the object. What would theta be for the work done by this frictional force? What would F and d be?
These two formulas do not apply to this problem. A good starting point for these problems is:
<br /> W_{\rm nc} = E_f - E_i<br />
which means
(work done by non-conservative forces during displacement) = (energy at end of displacement) - (energy at beginning of displacement)
What does this give?
