(Conservation of Linear Momentum) Find u1 speed
In a one-dimensional completely inelastic collision involving a 2 kg particle moving at speed u1 and a 3 kg particle at rest, 60 J of kinetic energy is lost. The conservation of linear momentum is expressed as m1u1 + m2u2 = m1v1 + m2v2, leading to the equation 2u1 = 5V. The kinetic energy loss is calculated as the difference between initial and final kinetic energy, resulting in the equation Kfinal - Kinitial = 60 J. To find u1, one can substitute the expression for V from the momentum equation into the energy equation. This approach allows for solving the two equations with two unknowns effectively.
paola8
1. A particle of mass m1 = 2 kg moving at speed u1 makes a one-dimensional completely inelastic collision with a particle of mass m2 = 3 kg, intially at rest.
If 60 J of kinetic energy are lost, find u1?
2. Conservation of linear momentum:
3. Using the conservation of linear momentun formula...
2u1 + 3(0) = (m1 + m2)V
2u1 = 5V
I'm just not sure where the 60 J of ke lost fits in. The loss in kinetic energy of 60 J means
Kfinal - Kinitial
which is
[.5(m1 + m2)v^2] - [((.5)m1u^2) + ((.5)m2(0)]
But there still remains the unknown variable of u, meaning I went in a circle.
You have two equations and two unknowns. There are many ways to solve this. One is way is substituting your answer for v in terms of u1 from the momentum equation into your energy equation. Then solve for u1.
Thanks! Once again, I'm left feeling dumb after such a simple solution.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
