Conservation of momentum at Annihilation
max_emerso
If you have a proton and an anti-proton traveling in the same direction with momentum from A to B but during the flight time they become attracted due to their opposite charges and annilhilate, the momentum I would guess is transferred to the resulting unstable K particles mesons etc, which, as I understand it, further breakdown into Electro Magnetic Radiation (Gamma Rays?) and Neutrinos.
It seems to me from my limited research in positron/electron annihilation that each fundamental particle pair (electron/positron and quark/anti-quark) eventually decays into a Gamma Ray pair of equal strength and opposite direction (180 degrees) possibly at 90 degrees to the point of annihlation.
Can I assume that the original momentum of the proton and anti-proton would be dectable in the wavelengths of the resulting gamma rays? Or is the momentum transferred to the Neutrinos?
They are only opposite in the rest frame.
Intriguing. Of course they will be be in their own rest frame relative to each other.
Thread 'Why is there such a difference between the total cross-section data? (simulation vs. experiment)'
Well, I'm simulating a neutron-proton scattering phase shift. The equation that I solve numerically is the Phase function method and is $$ \frac{d}{dr}[\delta_{i+1}] = \frac{2\mu}{\hbar^2}\frac{V(r)}{k^2}\sin(kr + \delta_i)$$ ##\delta_i## is the phase shift for triplet and singlet state, ##\mu## is the reduced mass for neutron-proton, ##k=\sqrt{2\mu E_{cm}/\hbar^2}## is the wave number and ##V(r)## is the potential of interaction like Yukawa, Wood-Saxon, Square well potential, etc. I first...
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
