Conservation of Momentum Elastic Collision Problem
The discussion focuses on deriving equations for the final velocities of two masses in an elastic collision using the conservation of momentum and kinetic energy. Participants outline the relevant equations and attempt to manipulate them to isolate the final velocities, \acute{v_{1}} and \acute{v_{2}}. A key suggestion involves using the center of mass reference frame to simplify calculations, where total momentum becomes zero. The challenge lies in managing the algebraic complexity, particularly when substituting and rearranging terms. Ultimately, the conversation emphasizes the importance of careful algebraic manipulation and the potential benefits of changing reference frames for clarity.
efekwulsemmay
I am basically being asked to use the law of conservation of momentum and kinetic energy to derive two equations for the final velocity of the two masses involved in the system. (i.e. \acute{v_{1}} and \acute{v_{2}})
Conservation of Momentum: m_{1}v_{1}+m_{2}v_{2} = m_{1}\acute{v_{1}}+m_{2}\acute{v_{2}} (Simply referred to as Therom 1)
Conservation of Kinetic Energy: \frac{1}{2}m_{1}v_{1}^{2}+\frac{1}{2}m_{2}v_{2}^{2} = \frac{1}{2}m_{1}\acute{v_{1}}^{2}+\frac{1}{2}m_{2}\acute{v_{2}}^{2} (Simply referred to as Therom 2)
For both equations: m_{1}\neq m_{2} , v_{1}>v_{2}
I know that we can get rid of the fractions from Therom 2 by simple factoring and multiplication:
m_{1}v_{1}^{2}+m_{2}v_{2}^{2} = m_{1}\acute{v_{1}}^{2}+m_{2}\acute{v_{2}}^{2}
Then we can solve for an arbitrary final velocity, say \acute{v_{1}}, with Theorm 1:
a.m_{1}\acute{v_{1}} = m_{1}v_{1}+m_{2}v_{2}-m_{2}\acute{v_{2}}
b.\acute{v_{1}} = \frac{m_{1}v_{1}+m_{2}v_{2}-m_{2}\acute{v_{2}}}{m_{1}}
c.\acute{v_{1}} = \frac{m_{1}v_{1}+m_{2}\left(v_{2}-\acute{v_{2}}\right)}{m_{1}}
Now we solve for \acute{v_{2}} by substituing in for \acute{v_{1}} the equation that we just solved for:
a.m_{1}v_{1}^{2}+m_{2}v_{2}^{2} = m_{1}\acute{v_{1}}^{2}+m_{2}\acute{v_{2}}^{2}
b.m_{2}\acute{v_{2}}^{2} = m_{1}v_{1}^{2}+m_{2}v_{2}^{2}-m_{1}\acute{v_{1}}^{2}
c.m_{2}\acute{v_{2}}^{2} = m_{1}v_{1}^{2}+m_{2}v_{2}^{2}-m_{1}\left(\frac{m_{1}v_{1}+m_{2}\left(v_{2}-\acute{v_{2}}\right)}{m_{1}}\right)^{2}
(the \frac{1}{m_{1}^{2}} and the m_{1} will cancel out one of the \frac{1}{m_{1}^{2}}'s to get...)
d.m_{2}\acute{v_{2}}^{2} = m_{1}v_{1}^{2}+m_{2}v_{2}^{2}-\frac{m_{1}^{2}v_{1}^{2}+m_{2}^{2}\left(v_{2}-\acute{v_{2}}\right)^{2}}{m_{1}}
Basically its at this point were my brain explodes from all of the m's and v's and their appropriate subscripts. I still have a \acute{v_{2}} on the wrong side of the equals sign and have no idea how to get it on the right side other than voodoo magic and satanic rituals (not really but I'm almost at that point). Any help would be appreciated. :smile:
There is a very nice method to derive the formulas for v1' and v2': Arrange both equations so that the quantities with index "1" are on one side and those with index "2" on the other side.
m1v1-m1v1'= m2v2'-m2v2
and
m1v12-m1v1'2= m2v2'2-m2v22
Factor the second equation and divide by the first one., you get a very simple relation between the velocities. Try.
ehild
From theorem I you get
m1v1 - m1v1' = m2v2' - m2v2-------(1)
From theorem 2 you get
m1v1^2 - m1v1'^2 = m1v2'^2 - m2v2^2-------(2)
Dividing 1 by 2 you get
(v1-v1')/(v1^2 - v1'^2) = (v2' - v2)/(v2'^2 - v2^2)
On simplification you get
v1 + v1' = v2 + v2'----(3)
Substitute the value of v2' in eq. no.1 to get v1'.
Ok I understand the whole dividing the two equations part but I am stuck trying to solve for the general equation. This is what I have:
\frac{v_{1}-\acute{v_{1}}}{v_{1}^{2}-\acute{v_{1}^{2}}}=\frac{v_{2}-\acute{v_{2}}}{v_{2}^{2}-\acute{v_{2}^{2}}}
I am not sure where to go from here. I tried to cross multiply but it looked like it would get messy so i gave that up and now I don't know where to go.
However complicated it may seem, it's only a quadratic in v_2^'. just multiply everything out and group the powers of v_2^'.
A more elegant way to do this is to use the reference frame of the center of mass of m1 and m2
the speed of the center of mass is:
u = \frac {m_1 v_1 + m_2 v_2} {m_1 + m_2}
now the new speeds w_1 and w_2 are v_1 - u and v_2 - u.
In this new reference frame, total momentum is 0, and it is much easier to find w_1^' and w_2^'
Now factorize the denominator.
v1^2 - v1'^2 = (v1 + v1')*(v1 - v1')
v1 +v1' = v2 + v2'
Write v2' =... and substitute in the eq. 1 to get v1'
