Conservation of Momentum, Energy
A bullet with a mass of 20 grams and a velocity of 100 m/s collides with a stationary wooden block of 2 kg, which is connected to a spring with a spring constant of 800 N/m. The conservation of momentum is applied to find the final velocity after the collision, followed by using energy conservation to determine the maximum compression of the spring. The initial calculations led to confusion, with the incorrect answer of 0.49 meters being noted. After recalculating with more precision, the correct maximum compression of the spring was found to be approximately 0.0497 meters. This highlights the importance of accuracy in calculations when applying physics concepts.
SuperCass
A bullet with mass 20 grams and velocity 100 m/s collides with a wooden block of mass 2 kg. The wooden block is initially at rest, and is connected to a spring with k = 800 N/m. The other end of the spring is attached to an immovable wall. What is the maximum compression of the spring?
p=mv
K=.5mv^2
Spring potential energy = .5kx^2
I tried doing M(bullet)V(initial) = [M(bullet) + M(block)][Vfinal], and then I used that final velocity in the energy equation .5mv^2 = .5kx^2 to find x. I keep getting the answer to be .49 meters, but this isn't correct.
What am I doing wrong?
Thanks!
I think you have the concepts correct and are just doing the numbers wrong. With these inputs, 0.5mv^2~=1J = 0.5 kx^2, so x^2 ~= 1/400 m^2. How are you getting 0.49m?
Whoops, I mean I keep getting .049 meters.
But still, doing what you said isn't giving me the right answer!
Okay, I got it, never mind!
I was doing it correctly, I just didn't put in an exact enough answer!
It ended up being .0497!
