collectedsoul said:
I realized that the conservation follows as a natural consequence of the Lagrangian formulation.
About the relation between symmetry and conservation:
Here is how I understand the gist of Nöthers theorem (as applied to physics). This is my personal opinion. (I believe my interpretation is the mainstream one, but just to be on the safe side I call it my personal opinion.)
When you formulate a theory of motion you formulate concurrently a coordinate system to represent that motion. Thus you have spatial coordinates and a time coordinate, and then velocity is defined as the
time derivative of the position coordinates.
Nöthers theorem is about coordinate systems and equations of motion.
The Newtonian formulation uses a uniform coordinate system. (Obviously you're going to use a uniform coordinate system; using a uniform coordinate system is what makes it possible to formulate equations of motion)
Here,
uniform coordinate system is meant in the following sense: If you have an infinite grid, then you cannot tell where you are on that grid. Every shift of position ends at a position that is indistinguishable from the previous position.So you have two definitions in place:
- velocity is defined as the time derivative of position
- the coordinate system is uniform.
Those definitions are already enough to imply Newton's First Law.
Consider: with the above two definitions in place, is there any way to get a motion that does not follow Newton's First Law? I don't think there is.
Now to the other type of conservation of momentum:
What about the total momentum of a system of two objects that are interacting with each other? (Attracting each other, or exerting a repulsive force on each other.)
Definition: acceleration, a, is the time derivative of velocity
Law of motion: a = F/m
Definition: the coordinate system is uniformNow some everyday physics:
You want to open a door, but it's somewhat stuck, so that it takes a bit of force to open that door. There's enough strength in your arm, but if pull that door very slowly you will only pull yourself towards the door. So instead of pulling slowly you pull
fast. And then the door comes unstuck.
What happens there is a straight example of F=ma, the Second Law.
By pulling very
fast you give yourself a big acceleration (for just a fraction of a second) and the bigger the
acceleration you give yourself the bigger the
force that you exert upon the door. The same applies for a pair of objects that is exerting a force upon each other. For each object: in order to exert a force upon the other object it must be in acceleration itself (just as you have to accelerate yourself in order to exert a force upon that door)
a= F/m says that the object with the largest mass will accelerate the least.
The acceleration will be in proportion, hence the velocities will be in proportion, hence the position of the common center of mass will not change.
So the following two:
Are already enough to imply that for interacting objects (attracting, repulsing, colliding) the total momentum is conserved
The general form of Nöther's theorem states that if you have a theory of motion (which means you have position, velocity and acceleration defined) then for each symmetry of the equations of motion (as defined on the coordinate system used) there is a corresponding conserved quantity in the theory of motion.
