Conservation of momentum problems
The discussion focuses on a conservation of momentum problem involving a grand piano and a pianist. The piano has a mass of 1250 kg and moves forward at a velocity of 0.06 m/s after the pianist pushes off. The pianist rolls backward at a speed of 1.4 m/s. Using the conservation of momentum formula, the calculated mass of the pianist is 54 kg. The initial calculations and methodology are confirmed to be correct.
ownedbyphysics
The larges grand piano in the world is really grand. Built in London, it has a mass of 1250 kg. Suppose a pianist finishes playing this piano and pushes herself from the piano so that she rolls backwards with a speed of 1.4m/s. Meanwhile, the piano rolls forward so that in 4.0s it travels 24 cm at constant velocity. Assuming the stool that the pianist is istting on has a negligible mass, what is the pianist's mass?
a. v of piano= s/t= .24/4=.06m/s
b. mp2= -mpvp,f/vp2,f= (-1250*.06)/-1.4 = 54kg
Correct me if I'm wrong, thanks!
Looks correct.
