Conservation of Momentum Set-Up
The discussion focuses on a physics problem involving the conservation of momentum as a freight car moves while coal is added to it. The user initially approached the problem like a rocket propulsion scenario but encountered difficulties in deriving the correct velocity function over time. A key point raised was the need to account for the changing mass of the system, as the mass increases due to the coal being added. The correct approach involves adjusting the differential equation to reflect the total mass as a function of time. Ultimately, the user received clarification that helped them arrive at the correct solution.
alexander_i
An empty freight car of mass M starts moving from rest with a constant applied force F0. At the same time, coal runs into the car at steady rate b from a hopper above the car at rest along the track. Calculate the velocity of the car as a function of time.
GIVEN: M = 1400 kg; F0 = 42000 N; b = 150 kg/s; t = 6.5 s.
I have a problem setting up conservation of momentum problems; I was wondering if there are some basic steps or factors to always look at, and help me understand the anatomy of them.
I tried treating this like a rocket ship problem-
Fexternal = F0 = d(mv)/dt
F0*dt = d(mv) -->
F0 = v*dM/dt + M*dv/dt = v*b + M*dv/dt
to differentiate--> F0 - v*b = M*dv/dt
--> (1/m)dt = (1/b)(1/F0/b - v)*dv
V(t) = [F0/b]*[1-e-b*t/m]
And plugging in I get 140.45 m/s which is not correct.
will someone help me understand the anatomy of the conservation of momentum, any helpful links are also appreciated. Thanks!
Your problem is that you forgot that m(t) = M + bt, so when you separated variables, your LHS should have been (1/(M+bt))dt
Think that should fix it.
I got: << solution edited out by berkeman >>
YEAH! Thank you for your help!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
