Conservation of Momentum Set-Up
The discussion focuses on solving a conservation of momentum problem involving a freight car and coal. The parameters include a mass (M) of 1400 kg, an external force (F0) of 42000 N, and a coal inflow rate (b) of 150 kg/s over a time period (t) of 6.5 seconds. The initial approach incorrectly treated the problem as a rocket ship scenario, leading to an erroneous velocity calculation of 140.45 m/s. The correct approach involves recognizing the changing mass of the system as m(t) = M + bt, which adjusts the differential equation and leads to the accurate solution.
  • Understanding of conservation of momentum principles
  • Familiarity with differential equations
  • Knowledge of external forces in dynamic systems
  • Basic physics concepts related to mass flow rates
  • Study the derivation of the rocket equation in physics
  • Learn about variable mass systems in mechanics
  • Explore the application of differential equations in dynamic systems
  • Investigate examples of conservation of momentum in real-world scenarios
Students studying physics, particularly those focusing on mechanics and conservation laws, as well as educators seeking to clarify momentum concepts in dynamic systems.
alexander_i
An empty freight car of mass M starts moving from rest with a constant applied force F0. At the same time, coal runs into the car at steady rate b from a hopper above the car at rest along the track. Calculate the velocity of the car as a function of time.
GIVEN: M = 1400 kg; F0 = 42000 N; b = 150 kg/s; t = 6.5 s.
I have a problem setting up conservation of momentum problems; I was wondering if there are some basic steps or factors to always look at, and help me understand the anatomy of them.
I tried treating this like a rocket ship problem-
Fexternal = F0 = d(mv)/dt
F0*dt = d(mv) -->
F0 = v*dM/dt + M*dv/dt = v*b + M*dv/dt
to differentiate--> F0 - v*b = M*dv/dt
--> (1/m)dt = (1/b)(1/F0/b - v)*dv
V(t) = [F0/b]*[1-e-b*t/m]
And plugging in I get 140.45 m/s which is not correct.
will someone help me understand the anatomy of the conservation of momentum, any helpful links are also appreciated. Thanks!
Your problem is that you forgot that m(t) = M + bt, so when you separated variables, your LHS should have been (1/(M+bt))dt
Think that should fix it.
I got: << solution edited out by berkeman >>
YEAH! Thank you for your help!
  • · Replies 27 ·
  • · Replies 42 ·
  • · Replies 17 ·
