Conservation of momentum with unknown angles
The discussion focuses on solving a conservation of momentum problem involving two masses with unknown angles. The equations provided relate the initial and final velocities of the masses, incorporating trigonometric functions for the angles α and β. The user has attempted substitution and combining equations but encountered difficulties, leading to the cancellation of coefficients. A suggestion was made to square the equations to find a solution for the angles. The conversation emphasizes the importance of manipulating the equations effectively to solve for the unknowns.
Chrismiss
Ma=2900kg Mb=730kg Va1=11m/s Va2=9m/s Vb1=30m/s Vb2=32.54m/s
∅=49.14
(2900kg)(49.14)+(730kg)(30m/s*cos(25))=2900kg(9m/s)(cos(α))+730kg(32.54m/s)cos(β)
and
(2900kg)(11m/s)+730kg(30m/s*sin(25))=2900kg(9m/s)sin(α)+730kg(32.54m/s)sin(β)
I have tried substitution by solving for cosα and also by combining the two equations which end up cancelling both coefficients
I need to solve for both alpha and beta given the two equations
Welcome to PF!
Hi Chrismiss! Welcome to PF! :smile:
(btw, you don't need to put brackets round those angles, unless your professor tells you to :wink:)
Let's see … you have
Acosα + Bcosβ = C
Asinα + Bsinβ = D​
… have you tried squaring? :smile:
