Conserved quantity for a particle in Magnetic Field
2 replies · 4K views · last reply
Siberion
Consider a particle of mass m and electric charge e moving in a uniform magnetic field given by B = Bẑ. Then the Lagrangian is given by:
[tex]L = \frac{m}{2}(x'^2 + y'^2 + z'^2) + \frac{Be}{2}(xy' - yx')[/tex]
Prove that [tex]Q={L} \cdot{B} + \frac{e}{2}((r \times B)(r \times B))[/tex] is a constant of motion, where L = r x p is the angular momentum.
I proceeded to calculate the conjugated momenta,
[tex]Px = mx' - ey/2[/tex]
[tex]Py = my' + ex/2[/tex]
[tex]Pz = mz'[/tex]
Then I calculated the Hamiltonian. A lot of terms vanished and I ended up with just kinetic energy.
[tex]H = \frac{m}{2} (x'^2 + y'^2 + z'^2)[/tex] which is a conserved quantity.
I was expecting to also end up with a term for the potential. Is this caused by the fact that the magnetic field does no work on the particle so it doesn't affect the total energy?
I expressed the hamiltonian in terms of the generalized momenta:
[tex]H= \frac{m}{2}(Px^2 + Py^2 + Pz^2 + \frac{(Be^2)(x^2+y^2)}{4}+eB(yPx-xPy))[/tex]I tried re-arranging Q in terms of the vector position r = xî + yĵ + zk , while p would correspond to m(x' + y' + z')
After doing dot and cross product operations, I ended up with the following expression for Q:
[tex]Q = (xy' - yx')B + (e{B^2}/2) (x^2 + y^2)[/tex]
which doesn't depend on z nor z', which gives me trouble when relating terms to the hamiltonian.
Is there any flaw in my procedure? I've tried rearranging terms, playing with algebra, but I don't come up with anything satisfactory.
Also, is the quantity Q a well known quantity? Is there something too obvious I'm missing here?
Thanks for your help. It is really, really appreciated.
In a uniform magnetic field, the scalar potential ##\phi## can be chosen to be zero. The vector potential ##\textbf{A}## can be chosen as ##\textbf{A} = \textbf{B} \times \textbf{r}/2 ##, so you could express the Hamiltonian in terms of the vector potential if you wished.
It all looks ok to me. Try taking the time derivative of ##Q## and see if it equals zero.
Thanks a lot TSny, according to what I calculated, using E-L equations, its derivative indeed equals to zero. I got lost trying to rearrange the Hamiltonian, I should have checked the derivative of Q at first.
