Constant Delta E-thermal in a given distance?
  • Thread starter Thread starter torquemada
    Constant Delta
The discussion centers on the concept that the change in thermal energy in a system is constant over a given distance, regardless of the force applied. It highlights that since the force (Fk) and distance (d) are constant, the thermal energy change remains the same. However, there is confusion regarding the physical implications, particularly when comparing the thermal energy generated by a racecar versus a slower car over the same distance. The intuitive understanding of thermal energy generation seems counterintuitive, as one would expect the faster car to produce more thermal energy. The conversation seeks clarification on this seemingly paradoxical relationship between speed and thermal energy change.
torquemada
In a given distance apparently regardless of how much work is done (whether the force is large or small) the change in thermal energy is the same since thermal energy change is fk times d. Since Fk is constant as is D the change in thermal energy of the system will remain constant. I'm having a hard time visualizing this though - isn't a racecar zooming through a slice of a track going to generate more thermal energy than a car mozying through that same slice at 5 mph? I don't want to just hide behind the math - it's a bit counterintuitive though when trying to picture it physically that the same change in thermal energy is occurring. tyia
Science news on Phys.org
bump for an easy question for a noob
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
