Constant Power, Variable Acceleration
The discussion revolves around a physics problem involving a car accelerating with constant engine power rather than constant acceleration. The key points include determining the car's velocity as a function of time, comparing it to a second car with constant acceleration, and calculating the minimum power required to win a drag race against an opponent with a known acceleration. The poster expresses confusion about the relationship between power, force, and variable acceleration, seeking guidance on how to approach the problem. Understanding how constant power translates into variable acceleration is crucial for solving the homework questions effectively.
cep
A car of mass m accelerates from rest along a level straight track, not at constant acceleration, but with constant engine power, P. Assume that air resistance is negligible.
a) Find the car's velocity as a function of time
b) A second car starts from rest alongside the first car on the same track, but maintains a constant acceleration. Which car takes the initial lead? Does the other car overtake it? If yes, write a formula for the distance from the starting point at which this happens.
c) You are in a drag race, on a straight level track, with an opponent whose car maintains a constant acceleration of 12.0 m/s2. Both cars have identical masses of 1000 kg. The cars start together from rest. Air resistance is assumed to be negligible. Calculate the minimum power your engine needs for you to win the race, assuming the power output is constant and the distance to the finish line is 0.250 miles.
P=dW/dt; W=F [dot] delta-r; F=ma
I'm pretty stuck at this one. My first thought is dW/dt=F [dot] dr/dt = F [dot] v = Fvcos[F-v]=P, but since a (and therefore F) are variable, I'm not sure where to go from here. Once I get the answer to A, I think I can do B and C (though the acceleration isn't mentioned in B, which I find confusing). Any hints? Thanks :)
Constant power means that energy is being given to the car at a constant rate. Where is that energy going?
  • · Replies 20 ·
  • · Replies 18 ·
