Constant source Poisson eq in 2D, Dirichlet BC, average value?
david.b
Hello,
for the Poisson problem Δu = -1 on a 2D circular disk with u = 0 on the boundary, we have
average(u) = \frac{1}{8\pi}Area(disk),
which is easy to see, as the solution is quadratic in the polar coordinate r. Does this (or a similar) relation hold for non-circular 2D domains? This problem comes up in Poiseuille fluid flow in tubes of non-circular cross section. Thanks in advance.
David
david.b said:
Hello,
David
Welcome to PF, David B. Nice to have you here.
Try solving this same problem for rectilinear flow between parallel plates. This is the limiting situation of a very low aspect ratio duct of rectangular cross section. I think you will find that the relationship does not hold up even in this case. However, there have been tons of papers published in the open literature for the laminar flow pressure drop/flow rate relationship in ducts of a wide range of cross sections.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
