Continunity In Function Spaces
  • Thread starter Thread starter jdcasey9
    Function
jdcasey9
Let fn:R->R be continuous for each n, and suppose that fn->f uniformly on each closed,bounded interval [a,b]. Show that f is continuous on R.
The definition of continuity that I will be using:
f:M->N
For any xcM, if xn->x in M, then f(xn)->f(x) in N.
Definition of uniform continuity:
f:M->N
fn->f uniformly if for all E>0 there exists an N(E) and for all xcM, all n>N, such that p(fn(x),f(x)) < E.
Let E>0 and take xcR. Since fn is continuous and fn->f is uniformly continuous on a closed, bounded interval, we can find xn such that xn->x, where xc[a,b] for large enough n. By the definition of uniform continuity we have p(fn(x),f(x)) = lfn(x)-f(x)l < E. So as E -> 0, fn(x)-> f(x).
Therefore, f is continuous on a R.
f:M->N
f:M->N
"fn->f is uniformly continuous" doesn't mean anything. Do you mean fn->f uniformly?
That is a confused statement. You can always find xn converging to x; that doesn't have anything to do with your functions.
Back to the drawing board. Pick any x and consider the interval I = [x-1,x+1]. You need to show that given any e > 0 you can find a d such that if |x - y| < d then |f(x) -f(y)| < e.
Think about using the triangle inequality by adding and subtracting terms using the sequence and what is given.
Let E>0 and E = d + 2ly-f(y)l + 2lf(x)-f(y)l. Consider the interval I = [x-1, x+1] with x,ycR. If lx-yl < d, then lx-yl <= lx-f(x)l + lf(x)-yl = lx-f(x)l + ly-f(x)l <= lx-f(y)l + lf(y)-f(x)l +ly-f(y)l + lf(y)-f(x)l = 2lf(y)-f(x)l + lx-f(y)l + ly-f(y)l <= 2lf(y)-f(x)l + lx-yl + ly-f(y)l + ly-f(y)l = 2lf(y)-f(x)l + lx-yl + 2ly-f(y)l < d + 2ly-f(y)l + 2lf(y)-f(x)l = E.
So, lf(y)-f(x)l < E.
Does that seem about right?
No, not even close. You haven't used anything about the fn in your argument so how could it be right?
Look, here's the general idea. You want to get f(x) close to f(y). So think about doing it by getting fn(x) close to f(x), fn(x) close to fn(y), and fn(y) close to f(y). The devil is in the details.
Ok, ok, I'm understanding.
Fix E>0 and let xc[x-1,x+1]. Since fn -> f uniformly on [x-1,x+1], for some n, p(fn(z), f(z)) < E/3 for all zc[x-1,x+1]. This fn is continuous at x, so for some delta>0, d(x,y)<delta implies p(fn(x),fn(y))<E/3. Then for such y, d(x,y)<delta, p(f(x), f(y))<=p(f(x),fn(x)) + p(fn(x),fn(y)) + p(fn(y), f(y)) < E/3 + E/3 + E/3 = E.
Therefore, f is cts on [x-1,x+1].
Does it logically follow that it is continuous on R? Or is there more to be shown?
You mean suppose E > 0. (You don't need to fix it unless it is broken :-p). Then you don't say "let x ε [x-1,x+1]". That is always true. You are trying to show f is continuous on R so you say pick x ε R and consider the interval I = [x-1,x+1]. Then if you show f is continuous at x you will know it is continuous on R because x could have been any real number.
You need to also require delta < 1 to stay on your interval.
Yes. See above.
Ok, thanks. I really appreciate it.
