Continuous functions on metric spaces with restrictions
6 replies · 3K views
tjackson3
Let [itex]E,E'[/itex] be metric spaces, [itex]f:E\rightarrow E'[/itex] a function, and suppose that [itex]S_1,S_2[/itex] are closed subsets of [itex]E[/itex] such that [itex]E = S_1 \cup S_2[/itex]. Show that if the restrictions of [itex]f[/itex] to [itex]S_1,S_2[/itex] are continuous, then [itex]f[/itex] is continuous. Also, if the restriction that [itex]S_1,S_2[/itex] are closed is dropped, does the assertion still hold? Explain.
Definition of continuity of a function from [itex](E,d)[/itex] to [itex](E',d')[/itex] at a point [itex]p_0[/itex]: A function is continuous at [itex]p_0[/itex] if for any [itex]\epsilon > 0[/itex] and [itex]p \in E[/itex], there exists [itex]\delta > 0[/itex] such that if [itex]d(p,p_0) < \delta[/itex], [itex]d'(f(p),f(p_0)) < \epsilon[/itex].
Let [itex]p, p_0 \in E[/itex] and let [itex]\epsilon > 0[/itex]. Then there are two cases to consider:
1.) Since in [itex]S_1,S_2[/itex], for any [itex]\epsilon > 0[/itex], there exists [itex]\delta > 0[/itex] such that if [itex]p \in S_1[/itex] (or equivalently [itex]S_2[/itex]), if [itex]d(p,p_0) < \delta, d'(f(p),f(p_0)) < \epsilon[/itex] by the definition of continuity. If, for the given choice of [itex]\epsilon[/itex], the corresponding [itex]\delta[/itex] is such that [itex]B_{\delta}^E(p_0) = B_{\delta}^{S_1}(p_0)[/itex] (i.e. if the ball of radius [itex]\delta[/itex] is entirely contained in [itex]S_1[/itex]), then by hypothesis, [itex]f[/itex] is continuous at [itex]p_0[/itex]. The same logic applies for [itex]S_2[/itex].
2.) Now suppose that the corresponding [itex]\delta[/itex] is such that [itex]B_{\delta}^E(p_0) \neq B_{\delta}^{S_1}(p_0)[/itex]. In other words, some of the elements of the ball computed in [itex]E[/itex] are in [itex]S_1[/itex], while some are in [itex]S_2[/itex].
I'm not sure where to go from here. I have an idea (just separating into two separate balls those elements of [itex]S_1,S_2[/itex] and applying the hypothesis), but this idea does not use the fact that the two sets are closed.
As for the final part of the question, if both sets are open, then f is continuous (due to a theorem involving the preimage of a function being open implying that f is continuous), but I feel like if one of the sets is open, while the other is closed, the assertion wouldn't hold. I think figuring out how to involve the fact that the sets are closed into the main part of the proof would go a long way to figuring this out, but I'm not sure.
Thanks so much for your help!
I've seen that that is the case iff the inverse image of an open set is open. To prove it for closed sets, is it just a matter of replacing the word "open" with "closed" in the proof for the open case, or is it more complicated than that?
No, I don't think replacing the word open with closed would suffice. But it's not that hard to show:
[tex]F~\text{closed}~\Rightarrow~Y\setminus F~\text{open}~\Rightarrow~f^{-1}(Y\setminus F)=X\setminus f^{-1}(F)~\text{open}~\Rightarrow~f^{-1}(F)~\text{closed}[/tex]
The other implication is analogous.
So a map is continuous if the inverse image of a closed set is closed. Can you prove it now?
Easy enough. Thank you so so much! I'm still not sure how to show that if one of those subsets is closed and the other is open, the function is not continuous, though. Any ideas on that?
Gotcha. Thanks again!
