Contour Integration: Evaluating Integral on Unit Circle
  • Thread starter Thread starter bwinter
    Integration
The discussion focuses on evaluating the integral ∫_{0}^{2π} (dθ)/(1+ε cosθ) using contour integration on the unit circle. Participants clarify the substitution of z = e^{iθ} and the transformation of dθ into dz, leading to a quadratic in the denominator. The presence of poles is debated, with one participant initially miscalculating the roots but later confirming that one pole does lie within the unit circle. The correct approach involves finding the residue at this pole to compute the integral. The conversation emphasizes the importance of accurate algebraic manipulation and understanding the implications of poles in contour integration.
bwinter
Evaluate \int_{0}^{2\pi} \frac{d\theta}{1+\epsilon cos\theta}
where \left|\epsilon\right|<1, by letting z=e^{i\theta} and cos\theta = (z+z^{-1})/2 and choosing contour \left|z\right| = 1, a unit circle.
I know this has something to do with contour integration, but there are no poles as far as I'm aware and I'm used to going from dz to d\theta that I'm a bit confused here as to what to do.
I've gotten as far as subbing in the relevant replacement, but I'm lost otherwise. Residues don't apply here, right?
Can you show us what you got after you rewrote the integral in terms of z?
I'm not sure how to do that either. I just replaced the cosine with what's written. Not sure how dtheta changes into dz.
You do it like you normally do. You start with z=e^{i\theta} and differentiate to get dz=ie^{i\theta}\,d\theta=iz\,d\theta.
Oh, ok I think I got this. Just needed a push in the right direction. If I do that I get a quadratic in the denominator which results in two poles, then I can choose one and integrate around it which results in a residue which gives the answer. Sounds right?
You can't just choose one and integrate around it. You're integrating along the unit circle |z|=1. Therefore you must take the pole that lies within this circle.
I've found that the poles exist at z=\frac{-1\pm\sqrt{1-\epsilon^2}}{\epsilon} which don't fall inside the circle. Does this imply there are no poles I have to be concerned about? I'm super confused what I'm supposed to be doing here.
I haven't checked your entire solution, but it seems you missed the 'obvious' z=0 pole.
Your roots aren't correct. I think you made an algebra mistake somewhere. What did you get in the denominator? I got \epsilon z^2+2z+\epsilon.
That's actually not a pole here, I don't think. Plugging in z=0 gives me \epsilon in the denominator.
Yep, that's what I got after I factored out the 2/i, in which case my roots are correct, as I double-checked them with Wolfram.
edit: Actually one of my roots does fall inside the circle after all. Do I find a residue for that pole?
OK, I see you fixed the expression for the roots in your earlier post. I wasn't sure if you got the wrong roots or just entered the wrong LaTeX. In any case, our roots agree now.
So, yeah, as you found, one pole is inside the contour. The contour integral will equal 2πi times the residue at that pole, so you want to find it.
  • · Replies 19 ·
