Contradicting Effective Potentials for Kepler's Problem
  • Context: Graduate
  • Thread starter Thread starter gitano
    Potentials
2 replies · 3K views
gitano
Hi,
I have a question that has been bothering me for a while now. For Kepler's problem we know that angular momentum [tex]M_{z}[/tex] is conserved and that the angular velocity [tex]\frac{d\phi}{dt}[/tex] is equal to [tex]\frac{M_{z}}{mr^{2}}[/tex]. When we substitute for [tex]\frac{d\phi}{dt}[/tex] in the expression for energy, we get an effective potential
[tex]U_{eff}(r) = U(r) + \frac{M_{z}^{2}}{2mr^{2}}[/tex],
which is correct.
However, when we substitute this into the Lagrangian, one of the signs changes and we arrive at an erroneous effective potential
[tex]U_{eff}(r) = U(r) -\frac{M_{z}^{2}}{2mr^{2}}[/tex]
which is clearly wrong. There must be some subtlety which I am overlooking that explains why you can't substitute this expression into the Lagrangian and arrive at the correct effective potential, or for that matter the correct Lagrangian.
I am also curious that if in general you can express a generalized coordinate in terms of a constant of motion (the coordinate is cyclic) is it also wrong then to make such a substitution in the Lagrangian as is incorrect in the Kepler problem.
Hi,
have a look at this: http://www.aerostudents.com/files/dynamicsAndStability/lagrangianDynamics.pdf"
Section 3.4 has your answer: when suppressing a coordinate through a conserved momentum, the Lagrangian is not invariant, you have to use the Routhian (actually if you change its sign, things look better) to transform the Lagrangian so that its Euler-Lagrange equations are the equation of motion
Routhian will turn out to be R=-T+Ueff (the correct Ueff)
Hope this helps
