Control strength of permanent magnet
Controlling the magnetic field from a permanent magnet can be achieved by using pole pieces to shape the field. The strength of the magnetic field diminishes as the distance from the magnet increases. Understanding the relationship between the magnet's position and the coil is crucial for effective induction. Techniques for enhancing or directing the magnetic field can improve performance in applications. Overall, the design and placement of components are key to managing the magnetic field's influence on a coil.
athul jyothis
How to control magnetic field produced by a permanent magnet which is being induced on to a coil ?
Don't quite understand your question but in general magnetic fields from permanent magnets can be shaped using pole pieces and strength of field decreases with distance from magnet .
Thanks for your valuable reply
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
