Convergence of sequences proof
synkk
Given a sequence ## <x_n> ##, let ## <x_{n+1}> ## denote the sequence whose nth term for each ## n \in \mathbb{N} ## is ## x_{n+1} ##. Show that if ## <x_n> ## converges then ## < x_{n+1} ## converges and they have the same limit.
my attempt thus far
given ## \epsilon > 0 ## ##\exists N \in \mathbb{R} ## s.t. n > N implies ## |x_n - l | < \epsilon ## where l is the limit of ## x_n##.
now we need to prove that for given ## \epsilon > 0 ## ##\exists N_1 \in \mathbb{R} ## s.t. ##n > N_1 ## implies ## |x_{n+1} - m | < \epsilon ## where m is the limit of ## x_{n+1} ## and m = l
heres what I have thus far
consider ## |x_n - l |## :
## |x_n - l | = |x_n - l + x_{n+1} - x_{n+1} | = |(x_n - x_{n+1}) + (x_{n+1} - l ) | \leq |x_n - x_{n+1} | + |x_{n+1} - l| \leq |x - x_{n+1} | + |x_{n+1} - l | \leq |x_{n+1} - x | + |x_{n+1} -l | ##
any ideas how to proceed? or if I'm even doing it correctly
Not a bad try. But you want to show |x_{n+1}-l|\le \epsilon so you should start your inequality with that instead of |x_n-l|. Also when you break up the absolute value into two pieces, use what you know about the size of |x_n-l| and |x_n-x_{n+1}|. I'm not sure why you introduced "x", what is it?
If \{x_n\} converges to L, then, given any \epsilon&gt;0, there exist N such that if n> N then |x_n- L|&lt; \epsilon. Here, your second sequence, let's call it \{a_m\} has the property that a_m= x_{n+1}. Do you see that, for the same \epsilon, we can our new "N" to be the old N plus 1?
(This is a different method than ArcanaNoir's. Both will work.)
The x is the first term of the sequence
if I do x_n - x_(n+1) = x_1, x_2, x_3 ... x_n - (x_2, x_3, x_4... x_(n+1))
how do I evaluate |x_n-x_{n+1}|? I have no idea of it's size
No, I don't see that - I mean it kind of makes sense, but I'm not all that convinced.
Thank you for your help
Have you learned about Cauchy sequences?
At any rate, you know |x_n-l|&lt;\epsilon for all n>N. Well if n>N, isn't n+1 > N?
I have not learned about Cauchy sequences, all we have done is the definition of convergence and this is a question on my problem sheet.
I agree with the highlighted part, but I do not see how it helps.
thanks,
Maybe I just don't get what you don't get, but if
doesn't that mean |x_{n+1}-l|&lt;\epsilon? It's really simpler than what you think.
Yeah that makes sense actually,
but for a different proof:
I got from here ## |x_{n+1} - l| \leq |x_{n+1} - x_n| + |x_n - l | < |x_{n+1} - x_n| + \epsilon ## how do I evaluate ## |x_{n+1} - x_n|##?
That's really not a very good way to go. Because about the only thing you can say about ## |x_{n+1} - x_n|## is that since ##|x_n-l|<\epsilon## AND ## |x_{n+1} - l| < \epsilon## then ## |x_{n+1} - x_n| < 2\epsilon##, but you need the bound on ## |x_{n+1} - l|## to say that.
hm I see, but I just cannot seem to construct a proof using that if x_n is bounded then there n>N for some N then n+1 > N also
I don't understand why you don't see it. If n>N then n+1>N. It's automatic. The same N that works for the sequence ##a_n## works for the sequence ##b_n## where ##b_n=a_{n+1}##.
So that's all I'd have to state for the proof?
Yes, a proof could be that simple. Write it in a way that you understand it.
Thank you very much Dick, and everyone else who helped :)!
