Convergence of the sequence from Heron's method.
Coffee_
##a_1=1##
##a_{n+1}=\frac{1}{2} ( a_{n} + \frac{b}{a_n} )##
This should converge to ##\sqrt{b}## but I seem not to be able to prove this. Could someone give me a hint.
First prove that a limit exists. Show this by proving (by induction) that the sequence (starting from ##a_2##) is nonincreasing and bounded below.
One can define a new sequence \delta_1,\delta_2,\delta_3,\ldots by setting \delta_n=a_n-\sqrt{b}, and then solve an equivalent recursion formula for \delta_{n+1}. Proving \delta_n\to 0 can turn out more natural than proving the original claim directly.
First we prove that any term that is given by the recursion formula is either larger or equal to ##\sqrt{b}##.
##\frac{1}{2}(a_n + \frac{b}{a_n}) \ge \sqrt{b}##
This can be rewritten as :
##(a_n-\sqrt{b})^{2} \ge 0 ##
Which is obviously always the case. To conclude, any term starting from ##a_2## is larger or equal to ##\sqrt{b}##
Next we will look at when the succeeding term is non increasing:
##a_{n+1}=\frac{1}{2}(a_n + \frac{b}{a_n}) \le a_n ## ?
## a_n + \frac{b}{a_n} \le 2 a_n ##
##b \le a_n^{2} ##
This means that as long as the previous term was above ##\sqrt{b}## the next one will be smaller. However I proved that from ##a_2## all the terms are above ##\sqrt{b}## which means that from ##a_2## on it is non decreasing and bounded from below by ##\sqrt{b}##.
That is correct. So now you've shown that ##(a_n)_n## is decreasing and bounded below, which means that it converges. Now we use a dirty trick to find the actual limit of ##(a_n)_n##. We have
\lim_{n\rightarrow +\infty} a_n = \lim_{n\rightarrow +\infty} a_{n+1} = \lim_{n\rightarrow +\infty} \frac{1}{2}\left(a_n + \frac{b}{a_n}\right)
I'll let you do the rest.
Wow that is indeed a dirty trick! However it clearly does follow from it, thanks a lot.
It seems my advice wasn't useful for the precise requested task, but I insist that it can be useful for other purposes. For example here the sequence converges towards \sqrt{b} at a rate that is faster than exponential, and that can be relevant for numerical purposes, but it wasn't yet proven by the used tricks.
