Convergence or Divergence of a Series with Sinusoidal General Term
  • Thread starter Thread starter the_storm
The discussion revolves around the convergence or divergence of a series defined by the general term \( a_n = \sum_{n=1}^{\infty} n \sin\left(\frac{1}{n}\right) \). Participants are exploring various methods to analyze the series' behavior.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts the comparison test and the integral test but encounters difficulties. Some participants suggest trying the Nth Term Test and question whether the general term approaches zero as \( n \) increases.
Participants are actively discussing different tests for convergence and divergence. There is a mix of suggestions and attempts to clarify the problem, but no consensus has been reached regarding the series' behavior.
There are indications of confusion regarding the problem setup, with one participant suggesting a review of the question. Additionally, there is a reference to Cauchy's Fundamental test for Divergence, though it is not universally accepted in the discussion.
the_storm
an = sum of n * sin([tex]\frac{1}{n}[/tex] )from n =1 to n =infinity
Test the series for convergence or divergence
I tried the comparison test with bn = sum of n but it fails because an < bn
which means a series smaller than a divergent series and this gives me no information about the an ... I tried also the integral test but I couldn't do the integration ... so what do u think guys ?
Try the Nth Term Test. :smile:
Hint: Without doing the test, you can see that you'd be adding 1 forever...
check the problem again
It's not nice to change the question when the expert isn't looking...
Hence by Cauchy's Fundamental test for Divergence, as the limit is not zero, the series diverges. (http://www.math.oregonstate.edu/hom...StudyGuides/SandS/SeriesTests/divergence.html)
Since this isn't an alternating series, does the general term go to zero as n goes to infinity?
Edit: Didn't see SVXX's post before I replied. :wink:
