Convergence Test (Comparison) Questions
omer10000
Hello everyone,
I need some help on doing convergence tests (comparisons I believe) on some Ʃ sums.
I have three, they are:
1. Ʃ [ln(n)/n^2] from n=1 to ∞.
I tried the integral test but was solved to be invalid (that is, cannot divide by infinity). Therefore I believe it to be a comparison test but don't know what to compare it to.
2. Ʃ [(3n+2)/(n^3+1)] from n=0 to ∞
I solved the whole problem starting at n=1 and stating that Ʃ1/n^2 and Ʃ1/n^3 were larger and convergent, therefore the sum is convergent. I realized the n=0 part later and now cannot solve it cause you cannot divide by 0; that is, 1/0^2 or 1/0^3. I tried an index shift yet it still is invalid.
3. Ʃ [(2n+1)/n^2] from n=1 to ∞
I don't know what to compare this to. I need a value smaller than 1/n^2 which diverges (as sum diverges) but 1/n^3 converges. I don't know what to do.
Help would be much appreciated.
Thank you
Why would you want to "divide by infinity"?
A comparison can be useful - you'll need something "between" 1/n (-> sum is not convergent) and 1/n^2 (->sum is convergent, but it is not larger than your expression)
For convergence, finite numbers of initial summands are irrelevant. It is sufficient if your comparison works for n>2, n>1 billion or any other number.
The sum over 1/n^2 converges. You can split this into two series, both of them are easier to evaluate afterwards.
How should I go about determining which 'in between' fraction is convergent? Do I use trial and error, and then solve it geometrically?
mfb said:
For convergence, a finite number of initial summands are irrelevant. It is sufficient if your comparison works for n>2, n>1 billion or any other number.
Okay thanks for that so when I solve, I can just say that all values are positive for n≥1 and leave it to that. Then I solve without considering n=0.
I tried something like that but kind of got stuck.
a_n = (2n+1)/n^2 = 2n/n^2 + 1/n^2...1/n^2 is already convergent so don't need to worry about it.
2n/n^2=2/n...n > x? n is larger than what convergent value so that when I invert it, 1/n is smaller than 1/x --the convergent value.
Then do I say that 2/n < 1/x = convergent + 1/n^2 convergent = Ʃ sum is convergent by Comparison Test.
What could be interesting between 1/n^1 and 1/n^2?
Sure.
micromass said:
The harmonic series ##\sum \frac{1}{n}## is not convergent.
Alright so I say that since 1/n in DIvergent and 1/n^2 is CONvergent, the sigma sigma overall is DIvergent?
Sure.
Not sure, 1/n^1.5?
Right.
Not sure, 1/n^1.5?
That is a good idea.
