Test Series Convergence: 1! + 2! + ... + n! / (2n)!
  • Thread starter Thread starter dobry_den
    Convergent Series
dobry_den
Hi, could you please check if my solution is correct?
Test the following series for convergence:
\sum_{n=1}^{\infty}\frac{1!+2!+...+n!}{(\left 2n \right)!}
I can use a slightly altered series
\sum_{n=1}^{\infty}\frac{nn!}{(\left 2n \right)!}
whose every term is >= than the corresponding term in the original series.. and thus if this altered series converges, then the original one should so as well...
Then, if I use the limit ratio test for the second series:
\lim_{n \rightarrow \infty}\frac{(\left n+1\right)(\left n+1 \right)!}{(\left 2n+2 \right)!}\frac{(\left 2n\right)!}{n(\left n \right)!} = 0
This means that the altered series is convergent, and thus the original series is also convergent.
Is this reasoning correct? Thanks in advance!
Yes it is.
