Convert Mol/cm3 to PPMV: Pressure & Temp Considerations
  • Thread starter Thread starter sneez
    Approach
To convert mol/cm³ to ppmv, one must consider the gas's density and the air's density, using the formula ppmv = [(Gas density) / (Air density)] * 1.0e6. The term "ppmv" stands for "parts per million by volume," indicating its application primarily in gas measurements. It's crucial to convert all units to SI for accurate calculations, as the dimensional analysis shows that mol/cm³ and ppmv have different dimensions. Resources were shared for further understanding and sample calculations related to ppmv in gas contexts. The discussion emphasizes the importance of using the correct units and understanding the specific application of ppmv.
sneez
I need to convert mol/cm3 into ppmv
how would i go about that if i know pressure and temperature ?
any leads ?
What's "ppmv"? I have a hunch it comes from "parts per million",bt what does "v" stand for ?
1 mol/cm^3 is the cgs unit for concentration.
Daniel.
parts per milion per volume , you just multiply ppm by 1.0e6
Are you using ppmv with gasses? A google shows that this appears to be the standard usage.
http://www.ch4.org.uk/glossary.php/Ppmv?term=p
has the usage info,
http://www.rotronic-usa.com/datasheets/Ref/Def/ppm_v.htm
has some sample calculations of how the term is used (with gasses).
If the term is being used for something other than gasses, the approach in the second url probably won't work - but I think it would be a bad idea to use the term for anything other than gasses.
I think i can work with that. Thanx a much
I hope u realize you can't make that conversion
dim (mol/cm^3)= S V^{-1}
dim (ppmv)=V^{-1}
Daniel.
yeah i had to convert everything into SI units.
ppmv=[(Gas rho) /(air rho) ] * 1.0e6
Gas rho = P/(kT) from P=nkT
thanx very much guys
