Convert Longitude/Latitude to cartesian x,y
The discussion revolves around converting latitude and longitude coordinates into Cartesian x, y values for plotting on maps. The context includes practical applications related to mapping and geodesy, with a focus on achieving sufficient accuracy for visual representation.
  • One participant seeks advice on converting latitude and longitude to x, y coordinates for maps that are 512 pixels by 512 pixels.
  • Another participant suggests researching 'Universal Transverse Mercator' and mentions software for lat/long to UTM X/Y conversions.
  • The original poster notes that their current calculations are off by about 40 pixels and provides their calculation method, which includes adjustments for negative values.
  • A participant questions the type of map projection used, highlighting that most projections distort some features and that simple linear scaling may not yield accurate results.
  • The original poster clarifies that the maps use a gnomonic projection and are Lambert Conformal with specified standard parallels, expressing uncertainty about the implications of this information.
Participants express differing views on the accuracy of the original poster's approach, with some suggesting that the choice of map projection significantly impacts the conversion process. There is no consensus on the best method for achieving accurate x, y values.
Participants note the potential inaccuracies in the original calculations and the importance of understanding map projections, but do not resolve the specific mathematical steps or assumptions involved in the conversion process.
3saul
I have a series of maps from various parts of the world.
Each map is 512 pixels by 512 pixels. I also have approximate left, top, right and bottom latitude and longitude values for each map.
I'm wanting to plot variable lat/long value on the maps which need to be converted to x,y values - any advice on how to proceed?
3saul: You are getting involved in an area of surveying known as geodesy. I think you should Google the term 'Universal Transverse Mercator' to learn the basics. Software to handle lat/long - UTM X/Y conversions can be downloaded from the US Army Corps of Engineers website - Google 'CORPSCON'
I forgot to mention, the map width is equal to 1024km - as is the height (so each pixel equates to approx. 2km).
SteamKing, thank you for your response. I've looked over some of the information, which seems relatively complicated for my purposes.
I don't need a huge amount of accuracy but my current calculations (below) aren't producing accurate enough results. The x/y are both off by about 40 (positive) pixels. This tells me my calculations are too simple.
currentlatitude = -27.445617
currentlongitude = 152.93503
--Make values positive
if currentlatitude < 0 then
currentlatitude = currentlatitude * -1
end
if currentlongitude < 0 then
currentlongitude = currentlongitude * -1
end
--The following are the coordinates for my map
mapLeftLong = 147.98
mapRightLong = 158.46
mapTopLat = -23.15 --was a negative figure
mapBottomLat = -32.31 --was a negative figure
if mapLeftLong < 0 then
mapLeftLong = mapLeftLong * -1
end
if mapRightLong < 0 then
mapRightLong = mapRightLong * -1
end
if mapTopLat < 0 then
mapTopLat = mapTopLat * -1
end
if mapBottomLat < 0 then
mapBottomLat = mapBottomLat * -1
end
xadjusted = mapRightLong - currentlongitude
yadjusted = mapBottomLat - currentlatitude
ypoints = mapRightLong - mapLeftLong
xpoints = mapBottomLat - mapTopLat--Get pixel value
globalXTranslated = (512/xpoints) * xadjusted
globalYTranslated = (512/ypoints) * yadjusted
3saul: What do you know about these maps you have? What kind of projection (Mercator, etc.) was used to make them? Most map projections distort some feature (direction, location, area, etc.) in order to produce a 2-D representation of the surface of a 3-D body. Unless you have a special map projection, a simple linear scaling of lat/long to X/Y will not be accurate.
The projection for the map images is gnomonic. They are Lambert Conformal, with standard parallels of 18S and 40S.
I hope this helps you to help me further. It means very little to me.
  • · Replies 19 ·
27K
  • · Replies 31 ·
